Story behind the bootloader updates
Field Trip
Inside Teenage Engineering’s firmware, from the OP-Z to the OP-XY.
I wanted to try out OpenAI DayBreak. A firmware rumor gave me something to investigate: the OP-Z and early OP-1 Field supposedly shared an encryption key. The original OP-Z hack had a write-up, but neither the recovery code nor the keys had been released. Would the explanation be enough to get it working?
Brad Trotter, _bt on OP Forums, had already recovered the OP-Z’s firmware and its key, with help from tolsi. That key also opened early Field updates. Then Field 1.1.6 switched to a different one. In his 2024 account, Brad said he’d more or less stopped there.
TabascoEye and other OP-1 owners had been taking its update files apart since 2016. The original OP-1’s outer archive exposed graphics, samples, and databases people could change. Understanding and rewriting the program was harder, but people kept at it. In May 2026, helvetica had added scale quantization and was asking whether anyone could get into the Field and OP-XY so features like that could come across.
I started with Brad’s firmware notes and public repository, writing my own recovery code around what he’d described.
The trick was in the updater’s status messages: it decrypted the filename and reported it back. Give it other encrypted bytes to read in that position, and it tells us what those say instead. The update can fail afterward; we’ve already got part of the answer.
My first attempt was on the Field. If the firmware was related, perhaps its updater would be similarly chatty. It would show “Decrypting firmware,” then fail, without telling me what it had decrypted.
To avoid risking my existing OP-Z, I ordered another.
Getting the first program out
A filename is supposed to be text. A program has zero bytes, characters that don’t print, and other things a string-handling function might mistake for the end of our message. I had to work out what survived the trip back from the OP-Z, where each response ended, and when a failed update was finished so I could start the next one.
Then the first archive block came back wrong.
These packages used AES in CBC mode. Decrypting a block also uses the preceding ciphertext block, or the initialization vector for the first block in a chain. Moving archive bytes into the filename’s place changes that relationship. One part of the published explanation treated the filename and archive as independently initialized regions, but that didn’t match what I was getting from my device. Accounting for the chaining relationship I observed turned the bytes into the expected ZIP structure.
flowchart LR
    accTitle: An error message becomes a data channel
    accDescr: The computer sends selected encrypted archive bytes as filename input. The OP-Z decrypts them with its own key and includes the result in diagnostics. The computer accounts for CBC chaining to recover plaintext. The update can fail after returning the bytes.
    subgraph computer["Computer"]
        encrypted["Encrypted archive<br/>Selected ciphertext"]
        recovered["Recover plaintext<br/>Account for CBC chaining"]
    end
    subgraph opz["Inside the OP-Z"]
        filename["Decrypt as filename<br/>Uses the instrument's own key"]
        diagnostic["Diagnostic response<br/>Includes decrypted bytes"]
    end
    encrypted -->|Update input| filename
    filename -->|Plaintext| diagnostic
    diagnostic -->|Error output| recovered
Figure 1. We ask for a filename; the OP-Z gives us part of a program. The computer accounts for the changed CBC context before putting those bytes back together.
A single response could carry several blocks. The logger could still cut it short or add formatting of its own, so the recovery program kept only complete returned blocks and saved its progress between attempts. An interruption didn’t have to mean starting over.
Brad had found the key inside the bootloader, the program that starts the instrument and handles updates. His published account described recovering the firmware ZIP first and searching the bootloader afterward. I started decompressing and searching while the bytes were still coming in.
The key turned up before the recovered bootloader was even complete. Once it checked out, the program stopped asking the OP-Z for more bytes. The key opened the whole stock archive on the computer.
Time to try the Field rumor. Version 1.1.2 opened. So did 1.1.4. Oplab opened with it too. Now I could read the early Field updater.
A few details about the files
Saving the official URL, version, size, and hash made each download easy to find again. By August 24, 2026, the collection held 93 files across 15 product families, about 2.95 GiB. Only ten appeared in the live updater feed. The rest came from official download histories and old links that still worked.
The original OP-1 used a CRC-wrapped compressed archive. Other products used encrypted containers, signed images, or different processors, so one unpacker wasn’t going to handle all of them. I could still compare the outer fields, lengths, checksums, and encryption boundaries before getting inside.
Every decrypted archive opened cleanly and passed its members’ integrity checks. Re-encrypting it reproduced the original download. That second check helped catch mistakes in rebuilding the container. It wouldn’t establish the right key on its own: using the same wrong key to decrypt and re-encrypt can also round-trip.
Without Brad’s scripts or comparable timing measurements, this comparison is limited to what he described publicly.
The Field changed keys, but left us some useful code
Field 1.1.6 wouldn’t open. Same container, same cipher, same CBC arrangement. What had changed was a field in the header telling the bootloader where to get its key.
Luckily, we now have an older bootloader to ask what that field means. It pointed to one-time-programmable hardware storage. And the old code already knew how to read it: the Field had been using that key source for the installed OS. The newer release started using it for downloads too.
Reading the hardware call still doesn’t give us the key it returns.
Searching the readable OP-Z software found its old key again, but no newer Field key. The OP-Z also had a similar hardware-key path; perhaps that would give us the same secret? It didn’t. I’d have to get it from the Field.
We have an early Field OS we can read and modify. If we can get it running, we can ask it to retrieve the key for us. But would the updater my Field was running accept the old software?
I tried keeping the old version identity while changing the encryption material. An intentionally incomplete package using the newer secure material reached decryption. The same identity with the original legacy-key material stopped at “Valid file not found.” The version number could get through; the old encryption couldn’t.
Then I noticed a rename in the early updater. It renamed a file, didn’t check whether that worked, and later opened the archive by its expected name.
Okay, but what if a file with that name was already there? The rename could fail and the updater would just keep going. When it went looking for the archive, it could find our existing file instead. We could let it check an encrypted input, then have it open a completely different, plaintext ZIP.
I tried an empty ZIP. Nothing to install. The device failed, which told me annoyingly little about which file it had actually opened.
A ZIP has a directory of its members and an end record locating that directory. In an empty archive, that record can sit at position zero. The recovered parser treated a zero-position result as failure. It might have opened my file only to trip over the first thing inside it.
I’d made the ZIP too empty.
For the next attempt, I gave it a directory it could enumerate, but still no extractable component contents. This time “Decrypting firmware” became “Extracting firmware.” Then it failed. There it was: the encrypted input couldn’t supply a usable archive, but my separate ZIP got it as far as extraction. Those display messages I couldn’t do much with at the start were suddenly enough.
flowchart TB
    accTitle: The file decrypted was not the file opened
    accDescr: The expected path preserves the identity of decrypted object A. In the recovered early implementation, an unchecked rename failure is followed by a filename lookup that can open an existing plaintext object B instead. The Field test observed selection of B, not the exact early-code instruction sequence.
    subgraph expected["Expected"]
        direction LR
        intended["Decrypted object A"] --> same["Open that same object"] --> parse["Parse A"]
    end
    subgraph observed["Recovered early implementation"]
        direction LR
        decrypted["Decrypted object A<br/>Encrypted-input gate passed"] --> rename["Rename fails<br/>Failure goes unchecked"]
        rename -->|Control continues| opened["Lookup by expected name<br/>Open object B"]
        existing["Existing plaintext B<br/>Already has that name"] -->|Supplies archive bytes| opened
    end
Figure 2. The early bootloader carries on after a failed rename and finds a different file under the expected name. On the Field firmware I was testing, the separate plaintext ZIP got me to “Extracting firmware,” then stopped before any component was installed.
The separate ZIP gave the early OS a way in without its rejected legacy-key envelope. I changed a small part of its response path to return the hardware-held key. The first attempt used a value left in memory, but it wasn’t clear whether that was the right key. The version that worked waited for the OS to initialize access to hardware storage, then read the key through that service.
The later Field releases opened.
And then I tried the TP-7. The same key opened all nine releases. The old OP-Z key hadn’t opened any of them.
I could rebuild an encrypted update with that key. I wanted to see a change from my edited file turn up on the recorder.
I put my name on the recorder
The TP-7 OS was much smaller than the Field’s. A label looked like a manageable place to start, so I changed USB MODE to USB CODE. One letter, same length, so we don’t have to move the string table or fix any pointers. I also changed the version metadata so the installer wouldn’t see an equal component version and skip my edit.
The package installed. The recorder rebooted and showed the new version. My label was nowhere to be found.
Following the string’s caller led to a transient overlay that lasted about a second. Of all the text in the firmware, this was something I couldn’t conveniently look at.
This time I traced JACKS to the root Settings menu before editing anything. Much easier to find. Starting again from the stock OS, I replaced it with ERICS. Four bytes changed; the S was already right.
This one installed and booted too. I opened Settings.
it says ERICS!
— My note during the TP-7 test, August 31, 2026
I’d used the real key for this edit, but the bootloader code had also turned up something that made me wonder whether we needed a secret key at all.
What happens if you don’t select a key?
The TP-7 had the familiar filename diagnostic. It also had a peculiar way of choosing a key.
We start with a key buffer in a predictable state. Pick a recognized key source and the code fills the buffer, then hands it to the cryptographic engine. But pick something it doesn’t recognize and we can skip the filling-in part. The code still hands over the buffer.
We already know what was in it. If we encrypt an update with that value, the updater can end up decrypting it with the same value. It never loads the secret it was meant to use.
I hadn’t tried this path on the TP-7; the menu edit used its recovered key. Alongside the label experiments, I was also following the TP-7 code toward the TX-6. I didn’t have its key. Could we get far enough into its updater to make it retrieve one?
First, the filename trick. The TX-6 returned a filename, then bytes from the encrypted archive. Following the ZIP structure led to the bootloader, which came back through repeated queries. The literal-key search that worked on the OP-Z came up empty here. This one asked the hardware for its secret.
This time we could use that odd key-selection behavior. I changed the recovered bootloader to call its own key-reading routine and return the answer, then prepared it using the predictable buffer value.
The TX-6 accepted the changed bootloader, ran it, and returned the hardware key. Back on the computer, that key opened the official package. Out came the same bootloader I’d spent all those queries collecting, byte for byte, along with everything else in the archive.
No OP-Z or Field key involved.
The OP-XY was not a copy-and-paste job
The OP-XY used the same generic browser MIDI implementation, and its package envelope looked familiar too. I tried the TX-6 approach.
It did not immediately cooperate. Several different mistakes produced the same generic response. Some attempts disturbed the CBC chain in the wrong place. Another preserved it but ran into a filename condition before reaching the diagnostic.
So, back to a known filename. A controlled change appeared in the response. Next came bytes that weren’t printable text, then bytes from the archive whose plaintext was unknown.
Eventually, a ZIP header came back. The direct USB-MIDI implementation recovered the complete 1.1.15 package, all 840 members. With the bootloader available to inspect and modify, the small key-returning change produced the OP-XY’s hardware-held key. Opening the official package on the computer then produced the same archive.
The OP-XY had its own key, different from the TX-6’s. I hadn’t started with either key.
flowchart TB
    accTitle: How discoveries moved between products
    accDescr: Arrows show the flow of research knowledge, not prerequisites for an attack. The OP-Z legacy key opened early Field and Oplab firmware. Later Field and TP-7 shared another key. TX-6 and OP-XY had independent physical tests and distinct keys. The TP-7 diagnostic and key-selection findings came from code analysis.
    note["Arrows show the flow of research knowledge,<br/>not attacker prerequisites."]
    opz["OP-Z<br/>Diagnostic oracle<br/>Legacy key recovered"] --> early["Early OP-1 Field<br/>Readable code exposed the key-source change"]
    opz -.->|Legacy key reused| oplab["Oplab"]
    early --> later["Later OP-1 Field<br/>Controlled recovery obtained the later key"]
    later -->|Shared key| tp7["TP-7<br/>Diagnostic and key-selection findings in code"]
    tp7 -->|Research continued| tx6["TX-6<br/>Independent physical test<br/>Its own key"]
    tx6 -->|Research continued| opxy["OP-XY<br/>Independent physical test<br/>Another distinct key"]
Figure 3. How the ideas traveled. OP-Z and Field kept opening up other products’ files; TX-6 and OP-XY each started with an unknown key.
None of this required breaking AES. The updater code printed decrypted bytes, chose a key it shouldn’t, or opened a different file after checking the input. A checksum was easy enough to satisfy too: if we can construct the file, we can construct its checksum. What was missing was an effective check that the software came from the publisher before the updater trusted it.
Later, in mid-September, I tried returning the TX-6 to stock. It was back in normal operation, but the temporary reader was still in its bootloader. Getting it to restart normally hadn’t put everything back.
Which versions I used, and what’s still untested
This work used firmware from before the October +1 fixes. The Field ZIP experiment ran on OS 1.7.3 / TE Boot 1000.1.1. The changed bootloaders ran on TX-6 OS 1.3.3 / TE Boot 1000.3.2 and OP-XY OS 1.1.15 / TE Boot 1000.0.13. All of this used the devices’ local update interfaces. I didn’t demonstrate an Internet-remote or zero-click attack.
The recovered TX-6 key opened all ten TX-6 releases in my archive. All 840 members of the recovered OP-XY package passed their integrity checks; its separately recovered key opened all nineteen archived OP-XY releases. Across that original corpus, four distinct keys opened 78 official packages containing 25,054 archive members, with the archive and round-trip checks described above.
The 59 retained Field, TP-7, TX-6, and OP-XY releases contained fourteen different packaged bootloaders. All fourteen included the diagnostic that could return decrypted bytes and a code reference to it. Related key-selection and decryption code kept appearing as well. I inspected those binaries without running the experiment on all fourteen bootloaders. The Field had already shown that having the code doesn’t necessarily give us a way to get the bytes back.
Both TP-7 label edits started from stock OS 1.1.11. My first package used version 1.1.12 and the ERICS package used 1.1.13; those were custom version numbers. The visible ERICS result ran under TE Boot 1000.0.7, using the recovered key. I found the diagnostic and key-selection problems in its bootloader code, but didn’t try those paths on the recorder. I prepared a stock-OS rescue package without installing it, and hadn’t checked whether every recording was preserved.
The unchecked rename came from an early Field bootloader. My Field opened the separate archive, but that didn’t tell me whether it used exactly the same instructions. On the TX-6, a familiar filename came back first, then archive bytes I hadn’t supplied as plaintext. Those couldn’t simply be an echo.
One TX-6 rollback stopped during transfer. A later browser attempt sent the official package and got the device back to normal mode, but the temporary reader was still active afterward. The OP-XY identified itself and communicated normally after its stock-target update, but neither bootloader bank had been read back. I couldn’t rule out a change still sitting in the inactive one.
The CM-15 packages used a different signed and encrypted MCUboot design, so I kept them outside this affected group. The counts here describe my collected files, rather than every release or device in circulation.
Disclosure update — November 3, 2026
I sent Teenage Engineering an encrypted report on September 9. They acknowledged it the next day. I asked them to authenticate the publisher before processing the contents, reject invalid key selections, and make sure the file they checked was the file they installed. Changing keys alone would leave the other mistakes in place.
The +1 firmware builds released on October 16 contain fixes from this research. On November 2, I went back to the downloads to see what had changed.
The old AES keys still worked.
I compared eight +1 packages with their older counterparts across OP-XY, Field, TP-7, and TX-6. Same OS, same content. Only the bootloader and version files had changed.
In the OP-XY’s new TE Boot 1000.0.20, I found code that checks a signed update header and the payload hash before reaching CBC decryption. The filename trick depended on it decrypting first and complaining afterward. This code rejects the old unsigned header before we get there.
We can even edit and re-encrypt the downloads, with a new checksum. What we can’t produce with that key is Teenage Engineering’s signature. That needs a different secret: their private signing key.
I verified the signatures on eleven official packages offline. On November 3, Teenage Engineering told me they had mitigated the issue. The revised packages are on the TX-6, TP-7, OP-XY, and Field download pages.
I haven’t rerun the attacks on updated hardware. I tested those update paths on devices in August–September 2026, using the older firmware named in the notes. I’m sharing the story and ideas, without the recovery code, raw keys, device identifiers, operational payload details, or modified firmware.
There was a lot more in the files
I’d been exploring the archives since the end of August, while the update experiments were still unfolding.
An early Field release had twelve files with no extensions and a small manifest describing rectangles. Image tiles, maybe? The bytes made sense as streams of 16-bit color values, with repeated values encoding runs of pixels. The decoded tiles fitted together into a 479-by-2140 onboarding page. The firmware had been carrying its own illustrated instructions around in twelve nameless pieces.
Elsewhere, the filenames were actively unhelpful. The original OP-1 had synth_0.raw through synth_6.raw. Sounds promising. All seven were the same one-byte placeholder. The TP-7 had rocker_calib.json and motor_calib.json; neither was JSON. They were four-byte and twenty-byte binary calibration records.
Even the actual raw samples could be misleading. They don’t necessarily tell us their sample rate or channel count, and some Field stereo material had channels so similar that reading it as mono looked plausible. The metadata settled the channel count.
By mid-September, I was trying to run the sound code on the computer. That meant finding how it received notes and parameters, and what it kept from one audio block to the next.
The OP-Z made a decent introduction: it shipped separate engine modules with descriptors for initialization, rendering, note-on, and note-off. The OP-XY’s main synth implementations were compiled into the OS instead. I’d have to find them inside a much larger program.
Fortunately, some source filenames had survived in diagnostic strings. We can follow a filename to an assertion, find the function containing it, then follow the callers. Little by little, anonymous functions become constructors, parameter handlers, renderers, and the routines they share. We don’t get the original source, but we do get some of its names. Even its typos: Dissolve’s file was called disolve.cpp, missing an s.
One wavetable routine seemed to multiply an index by forty, save it, and pass it to a helper that multiplied it by forty again. Forty was the record size. With index 2, that gives us 80, then 3,200. Why would it do that?
It wouldn’t. I was reading the operations from top to bottom, and Blackfin+ can issue several of them together in one packet. The multiply and the store were in the same packet. Both read the old register value.
So while the multiply calculates 80, the store is still saving 2. The later helper receives that 2 and calculates 80 for its own lookup.
flowchart TB
    accTitle: One instruction packet, two reads
    accDescr: With illustrative index 2 and 40-byte records, an incorrect sequential reading saves 80 and later computes 3200. In the actual parallel packet, both operations read the original 2. One computes 80 for the immediate lookup; the other saves 2 for a later lookup that also computes 80. These values are illustrative arithmetic, not firmware addresses or offsets.
    note["Illustrative arithmetic:<br/>index 2, record size 40 bytes.<br/>Not firmware addresses or offsets."]
    subgraph sequential["Incorrect sequential reading"]
        direction LR
        wrongIndex["Index = 2"] --> wrongMultiply["Multiply by 40<br/>2 × 40 = 80"]
        wrongMultiply --> wrongStore["Save 80"]
        wrongStore --> wrongLater["Later lookup<br/>80 × 40 = 3,200"]
    end
    subgraph parallel["Actual parallel packet: both operations read the original 2"]
        direction LR
        index["Index = 2"] --> immediate["Multiply by 40<br/>2 × 40 = 80<br/>Immediate lookup"]
        index --> saved["Save original 2"]
        saved --> later["Later lookup<br/>2 × 40 = 80"]
    end
Figure 4. The store and multiply happen together. Reading them as successive steps turns an index of 2 into a very wrong offset of 3,200.
The decompiler’s processor extension actually warned that its intermediate representation didn’t handle parallel instructions. I’d let the nice C-like output talk me into reading the code as a sequence.
With that corrected, the reconstructed wavetable renderer ran against all nine official banks on the computer.
A few things inside the instruments
Several of the instruments contain more than one computer. The main audio processor works with other controllers, radio firmware, and supervisory code. They don’t all use the same update formats or accept the same things. Getting inside the main program still leaves those other components to understand.
Each of the twelve Field guide tiles produced exactly enough pixels to fill its rectangle. Encoding them again gave me the original bytes. I also ran all nine official banks through the reconstructed wavetable renderer: the output repeated exactly, the final-bank boundary case worked, and invalid selections were rejected.
When I compared the Blackfin software, two pairs had more in common: TP-7 with TX-6, and OP-1 Field with OP-XY. They shared loader code and source-path references. That helped me find related code, but it didn’t mean I could run one product’s firmware on the other.
Inside the OP-XY, Simple, Hardsync, and Prism used one shared rendering core. Axis, Dissolve, and Organ used another. EPiano had its own recurrence. To run these on the computer, I had to preserve their arithmetic and state, including the values passed from one audio block to the next. There was still a lot between getting those routines working and recreating the whole instrument.
The project files supplied the other half
I’d started decoding the OP-XY project files at the beginning of September, before the synth reconstruction. Their notes, presets, and state could now feed the sound code. Other people were already working on .xy editing; the firmware also supplied the loading code to read alongside the files.
Functions named serialize80, serialize911, and serialize918 turned out to read project schemas 8.0, 9.11, and 9.18. The writer used the current format; the loader read older layouts and converted them into the current in-memory version. Some gaps in the numbering were simply versions sharing a layout and reader.
The 1.1.25 package contained 42 projects, eleven still using schema 8.0. Some compatibility code reached back further than the oldest public OP-XY firmware I’d collected.
Actually editing one was trickier than replacing JACKS. The projects used byte-run encoding: repeated bytes could be stored as a short run, and a run could cross a field boundary. Change one logical byte and the encoded file might grow or shrink, moving everything that follows. We need to decode it, edit a field we understand, then encode the result again.
The smaller .pxy files gave me another way to make sense of the numbers. Their repeated records looked like notes, velocities, positions, and durations. Interpret them that way and patterns start appearing: snare hits at 4 and 12 on a zero-based sixteen-step grid. Beats two and four! Chord changes at quarter-pattern intervals. A 303 pattern spanning the sixteen-step grid.
A promising file-reading path led straight into a filesystem self-test. The patterns were readable, but I still hadn’t found their importer.
Ask Why supplied sample events I could trace through preset selection, sample regions, pitch, and rendering. I got those selected samples into a preview on the computer, then added the recovered envelope and gain behavior, note-off handling, and release calculation. Now a note could select its sample, play it, and keep going through the release after note-off.
Next I connected loop selection and wrapping. Exported the audio again. Nothing changed.
None of Ask Why’s eight sample cursors had reached its loop boundary. Not even the release tails got that far. I’d added looping to music that never needed to loop.
Another factory project, Curio, had an event that actually crossed a stereo loop boundary. The renderer made it through the wrap, then stopped at the next transition I hadn’t figured out yet.
Making a song out of it
I put the working pieces into a composition called Ownerless Loop: an Ask Why sampler phrase, Jacket electric-piano bass, Chorale organ chords, and a Swell hard-sync lead coming in halfway through.
The first version had the computer supply the notes and mixing while the recovered engine code generated the parts. Could a project file carry the song instead of keeping the arrangement in my host code?
Building a project from nothing would have meant guessing at fields I didn’t yet understand. Ask Why supplied the skeleton and sampler state; Monium supplied synth-pattern state. The project contained all twenty-seven original Ask Why patterns plus thirteen new ones, with the 246 intended notes arranged across four scenes.
After writing the project, I read it back and passed its events to the renderer. A second decode, this time with an edited scene list, gave a new order for the already-rendered scene clips.
The result was sixteen bars at 120 BPM: a 32-second stereo mix, plus separate sampler, bass, chord, and lead stems.
A later check on pitch and timing
After the first project and render were working, I went back to a few misleading controls. I’d read track_scale as a possible musical scale selection, but the code and tables used it for timing ratios. The value in these patterns meant ordinary one-to-one timing. The saved octave field needed a closer look too. It didn’t shift every note on its own track by twelve semitones; the code applied that adjustment in certain routes to another track, using the destination track’s state.
I corrected my interpretation and added checks for those fields. The project and all thirteen audio outputs stayed the same, because these controls weren’t supposed to change this render.
The project renders on the computer, with parts of the timing, envelopes, mixing, and other processing still handled by the host. I’ve also reviewed the render and loaded, saved, and played the project on the OP-XY.
I started out trying DayBreak and ended up compromising firmware across the OP-1 Field, TP-7, TX-6, and OP-XY. That led to Teenage Engineering’s October +1 fixes.
Thanks for reading!
I think no one is interested in reading incomprehensible AI slop. If you know some interesting prime numbers just post them here.
i think the actual post is kinda interesting but the energy in the title is weird
The +1 updates added a check that an update actually came from TE before it was processed. Producing a valid signature now requires TE’s private signing key.
yes, they validate using asymmetric keys now.
its def a bit slop, I had to reduce a lot of the more interesting details, bc it is essentially still a workable direct path.
OP-Z plaintext oracle
→ OP-Z bootloader and legacy key
→ early OP-1 Field decryption with legacy key
→ discovery of the OTP-backed selector design
→ later OP-1 Field selector-0 key recovery
→ TP-7 decryption using OP-1 Field’s later key
→ discovery of the later filename oracle and unknown-selector fallback
→ reproduced both on the TX-6 and OP-XY
The OP-Z dump took 24 hours. I also discovered the same oracle in most of the other firmwares.
Another thing I didn’t point out - when I was dumping the OTP, I simply did it with a special SysEx command I added lol. To be perfectly honest, it was kinda accidental. I wanted to reproduce something never released. Then tested a rumor. And it goes from there.
Your story is interesting, now that we know about the dev mode in the bootloader.
They have made an update to protect the encryption while knowing that a dev mode exists (I mean, they are the devs…), a dev mode that lets you get the firmware unencrypted and that can be activated by a sysex sequence (if I understand the method explained in the GitHub repository well). So the worst security ever, if it was meant to be a security.
Still, this mode does not allow you to get the key, but… if you can get the firmware unencrypted, what is the point of that key?
I don’t know if they know that this mode has been discovered or not (maybe they’re too occupied with their new speaker product), but if future updates of the bootloader lock this mode, we will know.
it was actually added in the fixed versions, lol.
We should probably ban AI rambling posts like this, nobody’s reading this slop
Is it good spoil that for te? Next update will cover all that :banana:
The dev mode ? It was always here, the sysex sequence have been found by retro-engineering of the decrypted OP-1 Field 1.1.4 bootloader (te-boot 1000.0.34) – how decrypted ? I have an idea but not sure.
I can confirm I first enabled it on the previous version (not +1) and then I feared to update because of the rumor that the +1 bootloader version have fixed something useful for custom firmware lol.
This is really cool background info. Glad to hear some of the XY format reverse engineering was helpful.
Did you end up figuring out much of how to get into TP-7? I still really wish I could make some changes to mine.
Don’t read it then. I found this really interesting and helpful to understand some of the details.
Since I have the decryption keys for literally every product except for EP series things, I swept every version for that bug. When I’m at my computer I can post up an affected version matrix. But it’s amusingly new.
Yes, accidentally (and later I tried my findings themselves) because I figured out the were reusing their encryption key on TP-7 from the OP-1F… Which is exactly what the problem was when they reused the OP-Z on OP-1F and why I was able to pretty much figure everything out. I was flabbergasted when I realized they did it AGAIN.
i read it
I don’t know if it is a bug or an “undocumented feature” of the bootloader.
It depends on whether the sysex sequence is actually doing something that wasn’t meant to enable the dev mode in the first place.
From what I understand, it creates a bootloader.dev file, which is what seems to enable the mode, but I’m not sure if the presence of this file is the cause or the consequence of the mode being enabled.
it doesn’t seem to be a bug from my viewing. seems to have been accidentally left in.
