Hey guys,
pop at turn on, yeah. Happens all the time. pops with subby bass? Never noticed that. Have you tried adding a little attack?
Setting the release to 0/shortest in the Env page will result in clicks; I haven’t noticed that 0 attack produces clicks, but it’s possible that’s what’s happening.
Tape clicks sometimes have to do with recording while in loop mode. I usually deactivate my tape loops while recording and switch them back on once I’ve finished up. Otherwise held notes, effect tails, or release times are added suddenly to the beginning of the loop once it wraps around.
Hey guys, here is an example attached that I just recorded. It was with some moderate attack and release using FM. What do you think?
@KrisM @raigan here is an example attached that I just recorded. It was with some moderate attack and release using FM. What do you think?
So Michael, Did you find a fix to the popping noises???
Hi @tbird, thanks for checking. Were you able to listen to the little snippet I posted? I am kinda a noob, so I’m not sure if the sound is normal or not.
What’s your Drive setting in the Master section? Make sure its zero. That’s all I can think of,usually no clicks I’ve ever noticed on subbass attack.
Hi everybody.
Do you get this on most setting variations (not I including Green)on Cluster?
Have you checked your master section- Drive,EQ and master effects pages?Access these with the Mixer mode and pages 2,3&4.
Hi @Tomavatars I think I was hearing the same sound as you. I hear it on other synth engines as well such as FM. In Poly mode, I don’t seem to have this problem, but in Mono/Legato/Unison, I have to work around it.
Hi @Tomavatars I think I was hearing the same sound as you. I hear it on other synth engines as well such as FM. In Poly mode, I don't seem to have this problem, but in Mono/Legato/Unison, I have to work around it.@Spheric_El I tried turning the Drive all the way down, but no luck. I also checked the level in Tape to make sure I wasn't clipping.I think I'm just being anal about the sound. I can address it easily with Nitro or Punch.
Yup I tried those. It is hearable when green creates a filter enveloppe that smoothes the sound, so it is a real pain, as the sound should be nice.
