Hey everyone! I’m really new at all this, I have a M-Audio SP-2 sustain pedal, and id love to try and use it with the OP. Is there a way to do that?
I’m trying to play some heavier ambient shoegazey stuff, if anybody has any gear suggestions I would love to hear them.
Hey, its basically not possible to use a sustain pedal with the OP1 unfortunately. Similarly there is no key latch function. Here is a copy and paste form an email correspondence i had with TE about it:
Kindly,
Tobias
teenage engineering support"
and then this follow up to my reply:
“OP-1 is a class compliant USB MIDI device and need to connect to a USB host for MIDI operation.
oplab can provide this functionality if you do not wish to use a computer.
MIDI information used: (Sent / Received)
- Note On / Off ( √ / √ )
- Pitch Bend ( √ / √ )
- Velocity ( Fixed at 127 / √ )
- CC#1–4 ( – / √ using the MIDI LFO)
- MIDI Clock ( √ / √ )
- Song Position Pointer ( √ / √ )
- MIDI Transport ( √ / √ )
Kindly,
teenage engineering support”
I really wish the OP-1 had an expression pedal input. Controlling some of the Tape functions especially, via foot, would be epic!
Actually, I’m surprised TE haven’t broken out the tape section of the OP-1 and marketed it as a stand-alone recorder/looper. Just add a few more I/O options (expression, maybe some CV, MIDI sync) and you’d have a pretty broad potential customer base: synth-heads, guitarists, etc.
I vaguely remeber the pedals working on my piano when i routed it into my op1. i will experiment some more and report back.
The sustain button on my XKey doesn’t work when connected to my OP-1 via MIDIBridge
