Swing
Does the Opz swing per track or per pattern only?
Also has anyone figured out some of the more advanced tempo tricks available while holding the metronome button? It seems as though one gets a visual indication of the swing as 4 lights move across the sequencer. There is little info in the manual on this…
It honestly seems to be per project. I think tempo, swing, and drive effects are all per bank.
Yes I think you are right. Have you encountered what I mentioned – it seems as though the sequencer flashes 4 lights across the sequence according to the swing timing you dial in so you get a visual sense of how the track swings. Ive been unable to reproduce it again, but surely a result of my blind fumbling around with the unit.
