How would I go about syncing these two, and is it even possible?
I’ll try that. which sync mode should I place the OP-20 into?
Try this, instead of Monotribe connect PO, set sync mode on PO to SY2
Do I need to split the stereo from the DS10 into two mono as suggested in the video? I only have the DS10 and the PO-20.
I create the click track, press play on both and I hear nothing from the DS10 (as expected) but nothing on the PO-20 either when it’s in SY2 mode. Should I hear the PO-2O? Should there be an indicator on the PO-2O when it picks up the sync signal?
yes i think the am/pm blinks with the clicks. something blinks.
I’ve been unsuccessful.
Some else has tried, but I see no sync here https://www.youtube.com/watch?v=bsjS-Vcz6ik
Hey I tried, the click track sent by DS-10/DSN-12 can be recognized by KORG Volca Key, but cannot by PO…
I suppose TE’s PO has more stricter demand on Clock track signals.
I have emailed the support team to hear them advice…
If possible, we can sync up many POs wirelessly thru DS-10’s multi-player mode.
So, did you succeed?
The signal sent by NDS is too weak.
I managed to sync up PO by add an overdrive pedal in the signal chain, which is too complicated gear setup.
So I gave up…
wow that’s really complicated
I put a Zoom H1n in between a DS (very original one, not 3DS) and a PO-32, and it worked. But is it worth the effort, probably not. If you happen to have a really small attenuator, then the setup is really compact and not a hassle. Otherwise, just 3.5mm stereo audio cables are all you need.
