Hey u knowledgable people!
in Ableton preferences, go to the midi tab. make sure sync is ON for the OP-1. In the OP-1, make sure metronome is set to sync (not PO sync).
Thanx a million @mrbearnard ! Metronome to sync did the trick, great stuff!
You bet!
One thing to try if you end up with drifting issues (which you will) is to experiment with switching the MIDI Clock Mode for the device between Pattern and Song mode. I’ve found they help in different ways in different situations.
Thx jjbbllkk, i’ve just learned something new about Abletons synch settings.
I thought it might solve my problem, but somehow it doesent.
I just want to synch the OP-1’s Sequencers to Ableton, but every time i hit Play on my computer to start Ableton, the OP-1’s Tape starts from the beginging of the tape. But i don’t want the Tape to follow Ableton.
Does some one know how to solve this?
Has anyone come across a fix for this? I want to be able to sync the OP1 to Ableton but regardless of settings the OP1 acts like it’s being sent song position data as well as sync, so it always starts the tape at 0m00s. I want it to start the tape wherever I am (like, the beginning of the green loop range!).
Also looking for a solution… found any?
It’s my first time connecting OP-1 to Ableton, feels like I’m missing something that’s obvious to others 0_o
thx!
sorry no. it’s a bummer
Trying to do it with the OP-1 field. If anyone has found a solution, I would be interested…
Edit: it worked in midi sync
