Hello,
Does anyone know how to send MIDI clock from the TX-6 to the OP-Z ZM-4 module?
I’m using Loopy Pro on my iPhone as the clock master, syncing with my TX-6 connected to a USB-C hub, and everything stays in sync.
My Norns Shield also sync perfectly (via WiFi Ableton Link).
I could connect my OP-Z to the same hub to keep it in sync as well, but I’m wondering if there’s a way to sync the OP-Z ZM-4 through the AUX or CUE outputs of the TX-6.
I’ve successfully synced a Pocket Operator via TX-6 CUE, but I haven’t figured out how to do the same with the ZM-4 module.
TX-6 Settings:
- Clock SRC: USB
- Clock OUT: ON
- MIDI OUT: ON
- MIDI CTRL OUT: Note X
- CUE 16
I also tried syncing with a WIDI Uhost connected to the OP-Z’s USB-C port, but the sync is unstable.
Any suggestions?
Thanks!
