Synth app for OPXY
Hi all. I’m building an iOS AUv3 synth designed specifically to be played from an OP-XY, and I’d rather ask people who actually use one than guess.
Short version: it’s the Mutable Instruments Elements engine (modal physical modelling — bowed, blown and struck resonators) based on spectral IOS APP wrapped in a UI that copies the OP-XY’s own logic. Four encoders, one page at a time, a big readout while you turn, and a visualisation in the middle instead of a wall of sliders. No keyboard, no sequencer, no effects, the opxy already does all that. The idea is that your hands stay on the OP-XY and the iPhone is just a sound module with a screen that tells you what you’re touching. Same layout on both, so you’re not translating between two mental models.
Watch this vidéo for the sound modal /element module : https://www.youtube.com/watch?v=9rGOFCIA1-E&t=1019s
for the the original app, here it is : ‎Spectrum Synthesizer Bundle App - App Store
Where I need help is the parameter layout, because it has to match how you’d actually reach it.
If you were sending MIDI from the OP-XY to an Iphone (sorry android user I am lazy and as you guess its IA works), would you rather:
  1. Use the external MIDI track on the aux page — 8 assignable CCs across M2 and M3, which maps cleanly onto two pages of four, or
  2. Use an instrument track set to the “external” engine, so the synth sits in your normal track flow?
The reason it matters: the aux track gives a tidy 8 CCs but only one LFO destination. Instrument tracks would let you run several, each with its own LFO on a different parameter — at the cost of a track slot each. I don’t know which trade people actually make in practice.
Also curious how you’d route the audio, iPhone back into the OP-XY input, or straight out to an external mixer?
Thanks. Happy to share build if there’s interest. (open source project that will stay open source, not for sale)
And if if it works I would be interrested to translate other Braids sounds engine which are very fun, as a collection of other simple instruments as well.
