Hi there, I have a bunch of mellotron samples that i’d like to use with my OP-1 but I’d like to be able to import them from my PC rather than record each one in as a synth sample.
Is there a way to do this? Thaks for your help.
Yes, you just have to export them in .AIFF format and load them via USB.
Hi there, I have a bunch of mellotron samples that i'd like to use with my OP-1 but I'd like to be able to import them from my PC rather than record each one in as a synth sample.Is there a way to do this? Thaks for your help.
Importing will work fine but just quick heads up that you’re maybe better off using the Op1 drum utility app and preparing Mellotron as multisampled instrument in a drum sample instrument, instead of synth sample. Otherwise the sound gets very chipmunkish. Slightly better realism when multiple notes are multisampled in to a drumkit… ![]()
Ymmv tho.
