Tap tempo and tape
Is there a nice easy way to tap tempo a break and the tape loop length to correctly adjust itself to that tempo? So once I have tap tempo’d, I can stick on the metronome on the tape loop and have all 8 clicks perfectly looped in a 2 bar break? At the moment this isn’t happening, it’s only giving 7 odd clicks before the loop is up. Pain in the…
First tap the desired tempo; then go to the Tape and use the arrow to go forward or back to the closest bar marker after your last recording. Mark that as your in point.
Next all you have to do is count 8 bars forward and then drop your out marker there and you are good for a perfect 8 bars.
Thanks will try that! Cheers
