So, as I’m trying to make new sequences on the OP-Z I noticed that when I switch to the Tape function, none of the black buttons light up - there also seems to be no loop playback when i hit the grey keys. Has anyone ever had this happen? what do you do about it?
Also, when I click on the “I” in tape track, i see the black 1 and the first grey key blink white. if i hold down the grey key, all 16 of the track buttons go white. if I click on a different grey key, i can do it again and it appears to change to that “bank” - what is going on?
It’s odd that no black buttons are lit up, but What happens if you add a 16-step trig on the first step with something like C# (the 4 button) and F (first gray key)?
If you hold shift, do any tracks light up? All tracks included in the tape playback will turn yellow when you hit shift (e.g., the kick/snare tracks will have yellow lights on the sequencer), and it may be silent because you don’t have any tracks included. There are a couple other possibilities but I’d start with that one if I were you.
Even if this solves your problem, you may still find the tape track confusing (because it is confusing). In that case, I recommend this video that helped me a lot: https://youtu.be/ijqTsoHNxv0
When you press the track button (“I”) while on a track, the numbered keys indicate which plug you’re using and the component/gray keys indicate which preset you’re using. So the black 1 being highlighted means you’re using the first slot (which is normal), and holding down the component key saves your current settings as a preset on that key–indicated by the white lights on the sequencer.
