Tape markers
Is it possible to double the amount of tape markers instead of just one bar?
For bpms up to half the maximum, (can’t remember what because my OP1 will barely switch on at the moment), just double the bpm. This tip can be found in the hints and tips thread. Worth a fang.
thanks man…will have a look
Just keep in mind that if you double your BPM to get double the tape markers per bar, you will need to adjust your sequencers to match up with what you are expecting. 8th notes become 16th notes, etc. This shouldn’t be an issue for any sequencer other than the drum sequencer, since you can’t adjust whether they are 16th notes.
Ah believe if you double the Tape speed you will also double the amount of tape markers…
