'te-boot not working' issue solved
Hi, after struggling with this issue for a while and trying out a few things, I seem to have found a reliable and reproducible solution for the problem where the ‘te-boot’ bootloader of the original OP-1 is not accessible and therefore firmware updates and factory reset are impossible:
  1. Download the following file:
    te-boot-fix.op1
    If it ever becomes unavailable, please send me a PM!
  2. Rename it from ‘te-boot-fix.op1’ to ‘te-boot.op1’ - this is not optional!
  3. Power up OP-1 and connect it to a PC via USB
  4. Press Shift+COM and then the T3 key (DISK)
    OP-1 should show up as a USB drive on the PC soon after
  5. Copy the renamed file to that drive
  6. Press the T2 key (CTRL) on the OP-1
    Screen should now go blank for a short while and then display this message:
Imgur
  1. Power off OP-1
  2. Problem solved, you should now be able to access the bootloader by holding down the COM key while powering on the OP-1!
There is a post in this forum on a thread called “Well I’m Sad - Help” (can’t post the link since I’m a new user - sorry) that is almost identical to my solution (kudos to user ‘nthn’) except he said to press the T1 key which did not work for me. My firmware version is 242, his was 241, maybe that makes a difference? I don’t know what the oldest firmware version is, that supports this updating of the bootloader from within the application, I suspect it might have been added only after this issue became known to TE. IMHO it is inappropriate and disappointing that TE does not provide this solution openly in it’s FAQ but instead often seems to be recommending a costly exchange of the DSP board to its users.
I unpacked the mysterious firmware file using the op1repacker tool that can be found on GitHub.
The file only contains the bootloader executable (v2.29) called ‘te-boot.ldr’, I suspect that the .op1 file needs to be renamed to match this name.
Warning: if your firmware version is already 243 (last version that uses bootloader v2.29) or higher then this could be a problem since I don’t know if the bootloader is backwards compatible! If you’re feeling lucky you can use the op1repacker tool to extract only the te-boot.ldr file from a later firmware, repack it and try uploading that.
Hope that helps! (If not, please post your firmware version, visible during boot)
This does not seem to work for firmware version 225 so I suspect it won’t work for earlier versions either…
I have R.14203 on my OP-1 original. I bought it in 2012 and updated it in 2014. I’ve lost the ability to get to the boot screen, and I can confirm none of these fixes work for my situation, but I very much appreciate your efforts. Any tips, ideas, or advice you may have to get myself out of this predicament? If I try and sell it, this will surely be a big hit on price. I’d like to keep it, but now I have a battery that only lasts 2 hours, and a dead mic. I can make these repairs, but if I use TE battery and the TE i/o board I am looking at almost $200 USD. TE is really bad at supporting their products from my experience with this purchase. Thanks again.
I also have this problem, i have r14203 and everything is working great apart from accessing te-boot.
I know it worked when i bought it as i did the function test and it worked perfectly.
What i think may have happened was i had a usb cable connected when trying to boot into te-boot and that broke it and prevented me from accessing it ever again somehow.
Once its booted if i shift com and go to disk (3) then upload drum tracks etc it does what the original poster says and drops into some sort of te-boot finding the audio and adding it but dropping the te-boot.op1 file anywhere doesn’t get it to update the firmware.
I’ve tried putting it in each folder and it see’s it but its trying to do the other update and fails because its not the right file type. I’ve also tried creating folders called firmware, update etc etc placing it outside all the folders but it just deletes the file and doesn’t drop into the text screens.
The speaker does the small crackle when powering on normally and when trying to access te-boot but the screen doesn’t change and pressing 1 then connecting the usb does nothing.
TE have offered a op1 field for $1199 but i really just want to update the firmware on my current OG OP-1.
If anyone has any ideas on how to fix this I’d be very grateful.
i’ve tried these as well if i put the file into a folder and hold down com when it drops into the text mode the screen does go black and i have to disconnect the usb, physically turn it off and on again for it to boot up normally.
when i do it drops straight into scanning reading FAT contents, sees the 1 file added to the drum patch (te-boot.op1) ignoring the file in the root. and then fails to create the drum patch and sits waiting for me to press a key to continue.
I have good news for anyone who is looking for a fix: I’ve reversed engineered the firmware and created a bootloader patch that works for newer firmware versions (tested on version 246). You can find the file here.
Just tried to fix my OP1 with your new bootloader patch and it didn’t work on my unit (R218). The unit’s behaviour is similar to what @MadMcMan had reported last year:
  • when powering up the unit while pressing COM, the unit does not activate (there is no speaker pop upon power up, blank screen)
  • when put into disk mode, the unit accepts .wav files to subfolders, but does ignores the .op1 files in the main directory (tried the new bootloader and the older bootloader from the top of the thread)
  • if a bootloader is put in the unit’s main folder in DISK mode, turning DISK mode off (either by ejecting it from the computer, or entering CTRL/OP1 mode, or by powering the unit off and on) the unit does not react to the file - there’s now firmware checksum screen, nothing - the unit keeps running as if no update file was uploaded. And upon reentering DISK mode, the update file is deleted.
Is there anything else I can do to get the boot menu back?
