Guys, is anyone able to successfully sync OP-1 to a clock coming from modular via OpLab?
Task seems sipmle enough, and something that OpLab seems to be designed for, but it eludes me…
Mode “0” with sign,e source that is supposedly distributed to all other outputs should do it, right?
I see it is passing signal to MIDI out and to Host A where the OP-1 is connected, but OP-1 does not seem to recognize it as clock…
Any insight will be appreciated!
p.
hmm, anybody was able to sync op-1 to anything using oplab?..
Never tries it with the oplab, but I managed to sync the Op-1 from the Tanzbär via iConnectMIDI once… but it drifted after about 1 min…
It´s a shame because I like using OP-1 as my “daw”/tape recorder
I actually was able to sync it with iConnectMIDI as well, but not with OpLab!
Also, I sent TE an email directly asking for this information from them…
I suppose this might be the answer to my questions… if nobody uses Oplab in this fashion, then there is no support of it. OR it could be the other way around.
It makes me sad that TE does not even answer…
I just recently got an Oplab, and I find it very mysterious. The documentation isn’t the most helpful. I have a hard time even determining what mode I’m in. I’ve successfully gotten other gear to sync to the OP-1 (basically through trial/error), but I haven’t yet tried the reverse.
@wingo “Mysterious” is a nice way of putting it.
And same here: I can sync things TO the OP-1, but what I am unable to do is to sync the Op-1 to external source…
