Hello users,
This is my first ever post in a forum. I have troubleshooted my problem from the angles of the closest scenarios I could find on this board. I have tried almost everything. I emailed teenage engineering as well, have not heard back from them. It’s been 8 days.
I’m running Logic Pro X with a Focusrite 2i2 and the OP-1. I have set up as many others previously. I want to use the OP-1 as a synth in Logic using its own engines, modifiers, etc.
Strategy A:
OP-1 phones/out -> 3.5-1/4 jack -> line input one 2i2 ->2i2-> usb
Select Audio Track -> input input 1 + 2 -> output output 1 +2 (input monitoring check, record enable check)
turned off usb charging, also tried software instrument with the same inputs outputs
I am getting a signal to come thru and the notes are displayed,; however, there is no quality sound.
Please someone, anyone, this is the last step towards greatness, I need advice.
Also, I can’t load any of my samples from OP-1 into Logic for some reason?
I’m willing to video this issue.
Pls,
Nate
