The Legacy Collection, Jp-8 Factory Patches | Sound Pack | OP-1 | OP-1 Field
This pack is currently only available in the Exclusive Donor Vault.
Introduced in 1981, this synthesizer became an immediate benchmark for polyphonic analog synthesis. Built around eight voices with dual oscillators and a powerful modulation structure, it delivered a sound that was both expansive and precisely controlled—ideal for wide pads, expressive brass, solid basses, and harmonically rich leads.
Its clarity and balance made it equally effective in studio production and live performance, where layering and split capabilities encouraged complex textures without sacrificing immediacy. Over time, its sonic identity became closely associated with early ’80s electronic and pop music, while continuing to influence later generations of synthesizer design.
This OP‑1 Field sample pack focuses on capturing the instrument’s core character: spacious analog pads, focused harmonic layers, warm low‑end, and the distinctive sense of scale that defined its sound. Carefully translated into a compact format, these samples bring a classic polyphonic voice into a modern, portable workflow—ready to support new compositions with clarity and presence.
The Legacy Collection, Vol. 12: Jp-8 Factory Patches | Sound Pack | OP-1 | OP-1 Field
I signed up for the vault and it seems empty. Please advise.
Hi,
You should have received a notification from Google drive for your personnal access, be sure to check your spam folder. Otherwise, let me know (PM here) to figure out with you.
Thank you for your donation!
