Oplab is really spotty in terms of CV implementation/integration. Sometimes it works really well, and sometimes it just refuses to do again something it did before.
Just for the record: I was able to send CV from my modular into Oplab, and out as MIDI into laptop, or wherever, successfully. That seemed to work well
I also have the A-192-1 which is not necessary if you have Oplab. My experience with that Doepfer unit was that it works fine if/when it does not receive too much information too fast. Otherwise it chokes, slows down and sometimes hangs up entirely if I send a few streams of rapid CV changes at it… I am not sur what the performance of thenewer A-192-2 is like, never had a chance to try it.
The data generated by the module are transmitted simultaneously to Midi Out and USB. Two or more A-192-2 modules can be daisy-chained via Midi Out - Midi In. Incoming Midi data is merged to the Midi output - provided that the incoming data volume is not too high (because of the limited Midi Input buffer of the module). A Midi keyboard or a second A-192-2 are no problem but please do not try to merge a fully loaded 16 channel sequencer track.
@Polyoptics Your description of what the Oplab feels like matches mine exactly! I am mainly holding on to the hope that there will be a major overhaul of it and soon!
As to sync I waited for weeks for TE to respond to my inquiry about it, and finally I did receive a note that said that the only way to sync OP-1 to external source is throu the MIDI sync. So, I am thinking that I might get this guy:
http://www.analoguehaven.com/almbusycircuits/dsg/
and hopefully this will provide the sync signal that Oplab and Op-1 can inderstand… I actually sent TE a note asking their confirmation that this module would provide the modular to Oplab sync, but have not heard back yet. It does bug me though that I need yet another conversion gizmo to do something as basic as sync, while Oplab was supposed to provide this “make everything talk to everything” functionality.
These things are SO COOL and will probably push a lot of peeps over the edge into modular land (lookin at you VF):
Looks so dope, saw those vids a while back and was on modular grid GASing dream modulars for a few days.
@piotr Sweet that looks like a good module for sync! – I’d love to see some videos of you messing around with WW/MP and your crazy modular at some point. Def be sure to post here!
@Virtual_Flannel – if only it wasn’t so crazy expensive right?! I suppose if you build it up over time its not so bad, but I am a sucker for instant gratification!
Just for the record, the DSG module I linked to above does not allow to sync Op-1 to external sources as Oplab does not recognize DIN SYNC standard. I got the confirmation from TE that OpLab only recognizes incoming MIDI sync.
I see, thanks @piotr
Then I suppose something like this would do the trick for me, since I want to control the master clock from my MIDI gear:
http://www.doepfer.de/a1908.htm
Are you setting the master clock from your modular?
= I must NEVER put a finger in this modular fashion !
Even used Eurorack can hurt your bank account. Something the size of an IKEA RAST end table (6U, ie two rows of 3U Eurorack at 84hp wide) can easily cost a few grand depending on module selection.
560€ is already something…
Mutable stuff seems pretty exciting as well.
But I’d sell the house if I begin to GAS on modules.
I figured I’d post this here to get more modular perspective and because of the fact that I’d eventually like to go modular. At $180. this seems like a basic and inexpensive introduction. I’d also use this box to control CV with my Mininbrute. thoughts?
Looks like it responds to 0-15V, I don’t know what “standard” that is (lord knows Eurorack makers don’t stick to spec, either -_- ) You might need to run the MicroBrute through some electronics to feed this thing what it expects, or just let it alone and be happy with what does happen hehe.
Ah, I didn’t catch this till now @krism. Sorry, but I don’t understand half the things you’ve listed
This is my method of connection :
http://www.strymon.net/tag/expression-pedal/
As I put together my modular, the interest is ebbing instead of increasing. I’m not really sure why, but at least I tried it. I have an idea, though. It’s fun, but choosing modules, trying to find them at all to even buy when I think I might like one, it’s pretty frustrating and a little demoralizing. And then hearing them in context with what you have is usually impossible, though you can get an idea, and… yeah. Maybe it’s just not for me, but like I said, I tried. Trying to get my head around building sequencers w/ logic and such, as opposed to buying premade ones (which are way too fast/bleepy bloopy), is also a bit overwhelming despite being able to sorta do it with Max or Pd already. But that I can learn.
For me it was almost like at the beginning of my OP-1 experience: it took a while to get into it. But (also like the OP-1) it is not for everyone and I do think it is easier/quicker to get results with non-modular stuff. I had more results to show when I didn´t do eurorack… but I´ve found to love it and whatever works for you and so on
you’ll know if you are damaging something because it will clip and distort to all shit if you hammer the ADC too hard. I’d be more worried about pushing CV into it to use with the Element LFO, but if you’re worried just use an attenuator after the LFO module or smaller values (which are lower voltage)*
Hi,
Just wandering if Eurorack Modular levels are safe for the op-1 input?
Mainly because I’ve been using my modular as a sounds source for my sampler (which is amazing) and also as I’ve been using my lfos on my modular to modulate the ELEMENT LFO via the line in ( which is crazy awesome).
I know the modular can pump out some high levels so I just want to make sure I’m not damaging anything…
Cheers,
A
