Our 1 year anniversary contest is here, PERFORM using 1 of these 6 videopaks to win!
Details and Prize Info Below - - - - - - - - - - - - - - - - - - - - - - -
It’s been 1 Year since we started the Videloab Creator Community and we wanted to bring everyone together in an awesome ((((never before seen)))) “Videopak Master” contest!
CONTEST DATES: July 9th to Aug 6th
HOW TO ENTER:
Subscribe + Follow our YouTube and Instagram channels
Contestants will select from 6 videopaks provided(2 videopaks are on the OP-Z available to download now)
DOWNLOAD VIDEOPAKS HERE: https://bit.ly/3xJza3G
(Note: Download both the “Street Fighter” and “Megaman” paks before you start installing or before you start launching videopaks, if you get a “NO PAK LOADED” error, this is why, the street fighter and megaman paks need to be downloaded inside the app, this is a newer bug that is being worked out in the op-z app)
Create a compelling clip of your LIVE PERFORMANCE using one(or mashup) of these 6 paks in 1 minute or less. Only 2 entries per instagram account will be accepted.
Post your performance to your instagram and tag us @videolabcreators plus hashtag #vlc2021Contest. If you don’t have an instagram account then post a link(youtube or vimeo) in our discord channel of your performance, link to our discord is below
You can find us on Instagram here: https://instagram.com/videolabcreator…
PRIZES: 1st place //// TE - 3 pocket operators of choice + TE - patch / stickers + Retrokits - RK006 Midi Hub + VL Creators - Videopak Collection + Videolab T-Shirt + BOLT - 1 year of Bootleg club from the musician BOLT & sample paks + Synthdawg - ANY TWO Digital Guides from the Synthdawg.com Site + MyVolts - Pocket Operator Case(s) + Analog Cases - 3 PO Case +
2nd place //// TE - Choice of any 1 pocket operator + TE - patch /stickers + Retrokits - Passive Mixer + Videopak Creators - Videopak Collection + Videolab T-Shirt Bolt - Parallel Universe Breaks Sample Pack + Synthdawg - ANY Single Digital Guide from the Synthdawg.com site + MyVolts - 1 PO case +
3rd place //// TE - Choice of any 1 pocket operator + TE - patch + stickers Retrokits - A&B Midi adapters + Videopak Creators - Videopak Collection + Videolab T-Shirt Synthdawg - ANY Single Digital Guide from the Synthdawg.com site + MyVolts - 1 PO case +
4th & 5th place //// TE - patch / stickers + Synthdawg ANY Single Guide + Videolab Creators Videopak Collection + Videolab T-Shirt There will be 5 WINNERS selected from a
Panel of Judges:
+Cuckoo +Eran Hilleli +Tobias +Ryan Diefenbach +Perplexon +Bolt +Brad +Heymun +Synthdawg +MyVolts +Retrokits
After the Contest ends on Aug 6th, the top submissions will be posted in our Discord Server in channel #vlc2021Contest and those submissions will be sent to our judges and voted on. Our Discord Channel will contain more up-to-date information: Join the Videolab Creators Discord! https://discord.gg/7hKjcw3 ++++++++++++++++++++++++++++++++++++++++++++++++++
Tips & Tricks when performing with videopaks(With op-z)
To automate/animate the encoder values - While the op-z is playing, hold down the record button and twist the encoder value and those values should now be automated.
You can cycle through videopaks quickly using the “Shift + any of the numbered black keys”
Remember you can only record 4 key presses per step so you will have to work within this constraint. You get an additional 2 key presses(not recordable but real-time play) if you turn on “generous chords” but you still can’t record 6 notes
Use pattern chaining to mix things up and create new scenes and behaviors
Screen Record is built into every iPhone or iOS device and its the best way to capture a performance. If you just have an iPhone you can do two passes, one pass to record the screen and another to record the performance and edit them together in iMovie or Capcut. Layering is the key!
Bonus points to entries that tag a friend with an op-z or midi controller in the comments on our contest post in instagram✌️ ++++++++++++++++++++++++++++++++++++++++++++++++++
Videolab Creators linktree https://linktr.ee/videolabcreators
SHOW LESS
they are incredible !
