TP-7 with TX-6 multi recording
Not sure if anyone is using a TX-6 in conjunction with TP-7 but if you do you will know that the combination of both is meant to allow multi track recording with the TP-7. I can’t get it to work in multi track mode. Anyone would know what needs to be done/enabled? Seen from some videos that it seems to happen automatically once bother are connected via usb but I must have an option somewhere which needs to be changed as not happening, just recording as one track.
Thanks v much for any potential insights!
I assume you have them both connected via USB. You need to have the TX6 USB mode set to 12 in 12 out. You should see a little symbol on the TP7 and TX6 (from memory, I’m away from them). When in the correct mode and you hit record on the TP7 you’ll get a graphic to select the tracks on the TX6 you want to record.
Thanks v much. Not seeing the graphic on the TP but there is the option to select the number of track, MIDI options etc..Nit sure what else might need to be adjusted ..
