Hello op-z users!
An unexpected problem occurred when using the trigger spark component. I have always used it successfully, but recently I started getting strange results. If I program this component per step, with any value, then the track’s sound is simply canceled. he doesn’t follow the script. other components work fine. what am I doing wrong?
Does this happen on every project?
I will check it. but my project already contains a lot of patterns and I can’t refuse it…
The reason I’m asking is that I’m wondering it’s something related to a pattern or project setting or it’s a device fault. My guess (just a guess mind) is that there’s a weird interaction between multiple step components that you’ve used, that’s usually what does this kind of thing for me. Either that or parameter locks that are messing something up.
There were no parameter locks on the track, it was a kick drum. that is, only spark components. There are more than 120 patterns in the project and there has never been such a problem anywhere. I’ll try again.
I’d love to help but I think I’m misunderstanding your question. A trigger spark determines whether a note is played by the engine (and whether MIDI is sent out), so I’d expect it to cancel out the track’s sound.
I assume I’m just being dense here. Can you describe the issue in another way?
it,s a bag. in other patterns everything works as it should. another unexplained problem, it happens. Thank you for your answer and for your wonderful videos on YouTube.
