Hello,
Do you know some trick to sequence triplets on OP-Z?
Thanks!
Hello,
Thanks!
Hmm, a work around is set the triplet track to 12 steps and 4 bars (equals 48 beats per round) and the 4/4 parts to 16 steps and 3 bars, Max tempo is only 200 bpm so it is pretty slow but does allow per triplet editing.
Alternatively use the x2 multiply component set to x3.
Neither I suspect is exactly what you are after. Ability to see all steps in across bars would really help.
Thanks!
In theory you could use the micro adjust/ micro timing. Each step has a resolution of 24 ticks. 4 steps make 96 ticks. A triplet in these 4 steps should be every 96/3=32 ticks. Note 1 of the triplet is on step one. Note 2 of the triplet is on step 2 + 8 ticks. Note 3 of the triplet is on step 3 + 16 ticks. To achieve this, assign a note to step 2, press and hold step 2 button and press “+” 8 times, assign a note to step 3,press and hold step 3 button and press “+” 16 times.
Just tired it: hit step 1, 2 and 4, hold step 2 and hit + 8 times, hold step 4 and hit - 8 times. And you’ll have a 8th triad.
