I’ve been successfully sequencing external synths from the OP-Z over USB on tracks 14 and 16 (and 15 in a test). I know it says it is possible to send midi from all tracks but if I record notes into track 12 (Master) the notes don’t seem to send. I can play the keyboard and the notes sound, and I can also map a different track eg 15 to track 12 in the component track and it sends ok.
Is it possible to send midi notes from track 12? And (assuming that is possible) can you turn off the Master impact on all the drum and synth tracks so it doesn’t transpose parts based on notes input?
I don’t use the Master track for chord progressions but do use fx, tape, performance, so wanted use it for an external synth.
One quirk I noticed, doesn’t seem like it is possible to step input on track 15 but you can real-time record.
Ok I finally fixed how to sequence external gear from track 12/Master track.
On track 12 you need to set the notes to be “free” rather than “latch”. You do that by holding the track button and rotate the blue dial clockwise until the LED goes blue.
Magically that meant the notes in the sequencer were actually sent. I don’t know why.
