Excuse me but I can’t find any information about this on line if it is possible to use a tx-6 with connected different synth/drum machines (one on each input) , an ipad (connected via usb with the tx-6) with the AUM application. the goal would be to use the tablet to assign different effects (differrential for each audio input of the tx-6). As I understand it on the tx-6 you can configure it as a sound card with 12 separate inputs. AUM (actually ios) allows you to have multiple audio inputs as long as they come from a single sound card (and for this I believe the tx-6 does this without a problem), the question is to know if anyone has already used this method to enrich their set with more effects
I’m not sure I understand, but I have an OP-XY, OP-1f, and a Roland S-1 connected to the TX-6 with 3.5mm cables. The TX-6 is connected to the iPad with a USB cable. I set up 3 audio tracks in AUM, AUM sees the TX-6 and I choose stereo pairs 3&4, 5&6, 7&8 as the hardware inputs for the consecutive channels, leaving TX-6 channels 1&2 for monitoring AUM. The stereo sum of the 3 inputs is automatically output to TX-6 tracks 1&2, but I can route any inputs and outputs to any channels. I haven’t had a single issue recording in AUM this way.
