Question about the TX-6 effects. For some reason the tx-6 seems to “forget” about effects settings. I’ll set it to a small reverb, slight chorus and we’ll say a warp delay. Everything’s fine, but if I go in and change or even view the reverb setting now my delay and chorus are gone?? I have to “view” each effect to enable them again?
Also why does the “return” setting affect all three effects simultaneously? I can’t lower just the chorus or reverb?
Are these bugs? Or just something I have to live with?
I might be misunderstanding you, but: you can’t have chorus and delay and reverb on at the same time. You can select one effect at a time.
Now if I go from reverb to chorus to delay and change them around, it will not affect the settings of the others (but of course you’ll only be able to see and hear that when you switch back to said effect).
If you’re saying that editing your reverb will reset your chorus setting when you switch to it, that is a bug that shouldn’t occur and has never for me.
