Dumb Question …Going to own he OP-Z again after a while time but I’m confused on which patch is compatible with the OP-Z from the OP1.fun site as I see there are different ones ( not the Samples ) obviously mostly for OP-1.
The original OP-1 and the OP-Z share the same drum kit and sample format. So you should be able to use either of the Sample or Drum programs just fine.
Thanks, it was a bit of time and forgot that detail ![]()
