Unreleased TE field style bag spotted in Stockholm
With pure luck I noticed someone was walking with an unreleased TE field style bag like the TX-6’s and OP-1F’s. Had enough time snapping a quick pic from afar before the person disappeared through a nearby door on the street but not enough time running up and chatting with them. I wonder what was inside.
Only in Stockholm!
It looks like an all in one bag for multiple devices in the field series
the dimensions look like they are meant to fit the op-1f specifically, so im thinking it’s mainly for that and then any other smaller field devices/accessories to go in with it
I can see what you mean - but it looked quite a bit shorter than an OP-1 irl, the pic sadly doesn’t show it well
Was there TE branding on it? Might just be a white and black bag…
Yes, branding on the same type of black flap as on the tx-6 case
Fair enough, it’s probs too wide to be a op-z field so I’m actually not sure what else it could be :thinking:
what do you think?
On this video they’re showing another bigger unreleased bag…
Also is that a smaller rectangular Field Bag sitting on-top of the available OP-1 Field Bag. Possibly OP-Z kind of size? Maybe its the same one from Post 1 spotted in Stockholm?
You guys are like amateur Sherlock Holmes-types :slight_smile: :slight_smile:
Yup. currently they have these:
  • field small TX–6 bag
  • field large OP–1 bag
So what is missing on the second bullet?
Obviously “field medium OP-Z bag”. Mystery solved :slight_smile:
I guess the bigger question is if the bag is for the old OP-Z or a new OP-Z Field :grinning:
