Hi! Has anyone had a problem with a on/off-button which doesn’t always work? I’ve just experienced problems with the on-function, which was solved with flipping the switch a couple of times. Does anyone know if it’s fixable?
I bought my OP-1 second hand and when I first got it the unit would randomly reset - it was actually turning off then back on due to a faulty on/off switch.
Yeah had this a lot until I got a bit more patience and waited longer for the TE logo to pup up. Seemed to solve my problem. I used to spazz-out on the switch.
Recently discovered if I bump/tap my OP-1 near the switch it’ll do some reset fuckerydoo. That whole side of the hardware just seems sketchy hehe.
I haven’t charged it all the way through yet, so hopefully that will affect it positively. Everytime the on-switch works i hear a “sparkle-sound” before the TE logo, otherwise it just stays black and off. Thanks for all the quick answers, I’m a little bit less freaked out about this and hope it will sort itself out. Apart from this i’ve never had so much fun with a synthesizer!
@KrisM sounds like the same problem I had. it would turn off/reset when touching near the button too.
Probably some dirt in the switch. Work it out.
