USB HUB suggestions
Anyone have suggestions for a decent usb-c hub that would work with tx-6, op-1f, op-z and ipad? Eg mainly a usb-c hub with other usb-c ports
I’ve had good luck with Anker products.
Their usbc hubs also include a usbc PD port to power the hub, the host, and attached devices.
I got the Kingston Nucleum, it‘s the only one TE officially supports with the OP-Z for DMX communication… it works fine but makes a buzzing noise when not powered. I checked two and same issue.
Anybody found a usb hub that works well with op1f?
I want to be usb host to tx6 for midi sync to that (as tx6 is clocking out to other devices) and audio in from Tula mic?
Overall I want to have tula mic and clock or midi sync through any means, so… happy to hear suggestions.
Op1f used to do Bluetooth midi clock, and Bluetooth midi start/stop. But both were switched off in firmware by TE due to instability.
I’d like any way anyone can think of to have BOTH sync of some kind on op1f AND the usb port on op1f being used for Tula mic!
