Out of nowhere USB MIDI/Disk-Mode stopped working on my OP-1. It still charges over USB, so the port isn’t completely dead as it seems.
I’ve tried different ports on different computers (mac and pc), different USB cables and also did a factory reset but none of those solved the issue. Currently letting the battery drain so I can fully charge it back to see if that helps.
Any other ideas? Fortunately I’m already on the latest OS (which might be the last one?) but it’s a bummer to lose disk mode and USB MIDI. Any help appreciated.
i'd guess if spraying some compressed air or contact cleaner in the usb port doesn't fix it
that maybe u'd need one of those replacement connector boards?
or if yer real real handy w/ a soldering iron might be able to fix it that way?
Yeah, I was thinking opening the connector board, cleaning if needed and re-seating it.
I’m still inclined to think that it’s a logic error/OS glitch and not a faulty connector because it’s charging over USB.
I haven’t tried formatting the drive, I’m afraid to brick it this way. Does formatting erases the OS? What’s the difference between formatting the drive and doing a factory reset?
