I find the usb jack to be noisy. It’s weird, it’s not always noisy, but it is there regardless of whether the charging setting is on or off.
Could it be the cable I’m using? How’s everyone else’s?
I get it too sometimes. I put a ground loop isolator on the audio output. Like the one that comes in the Line Module box
Oh interesting - do you have a link to the item you’re referring to?
This one, for instance:
I have this one and it works great.
Nice.
u can also get ground loop isolator pretty cheap for your usb port as well
if u dont like putting one on your audio path
the usb ones are way more expensive at 50€+, the trs ones can be had for around 5€
I have a USB one, but it doesn’t work nearly as well as the audio one for me.
Unsure about Field, but it often depends on the device(s) you’re connecting to. So if a laptop, run from its batteries. Etc.
i’ve seen em for aorund $20 now
they used to be way more expensive
but obv YMMV
Just a follow up - I got an audio noise isolator for around $6 and it works great - no more noise. I ended up getting 2, 1 for input and 1 for output. I also got one which has a 2x 3.5mm female sockets that way I can position the isolator further away from the OP-1f keeping things minimal.
I’m getting noise coming out of the onboard speaker so I can’t use an audio isolator. do you think a usb one will work? I just want to play the op1 and listen from its speaker without the hum. thanks.
this is a brand new rev 2 version. my old rev 1 doesn’t do this
to clarify u are getting noise from your speaker only when u plug in the USB on your device?
like it goes away when u unplug it?
usb ground loop isolator may work
but ground loop is usually (not always) when u plug both audio and usb into the same thing and thus share grounds on both
could be whatever u are plugging the op1 usb port into that is just noisy for its own reasons
what are u plugging the usb into?
It happened with only the usb cable plugged in and listening to the onboard speaker.
The battery was completely flat when this happened - I left the unit switched on and charging for a couple of hours and when I returned the noise has disappeared. Must have been connected to the battery level somehow. Strange.
