I have a question about the usbc output signal of my opz.
For now perfect world, I can sample into my opz via usbc to usbc without adapter.
But as I found on the web , the opz can act as a USB hub and so sending out my output mix via usbc.
And it is true!! I have sound but I can not do something with it. First the sound is distorted but I am not sure if it is a level problem or a bit rate problem. To give an idea it is like it has some bitcrush on it.BSecondary the audio is speed up. Like if it was a sample rate problem. Like 44khz read a 48 or 96khz or the reverse. I do not know.
For sure there is a problem between my opz and my android phone. I have tried two recording app and I have the same problem. I have also change the cable usbc and always the same problem.
So if someone can tell me where I should change something i would be very happy.
I am on oneplus usbc last android system. Recording with wave editor app and vocal recording app.
I “bought” it but not with money from my own wallet. I use the google opinion rewards app https://play.google.com/store/apps/details?id=com.google.android.apps.paidtasks&hl=en_US It barely takes any time to answer the survey, they usually come often and pay out enough that it stacks up quickly and I can usually buy any app I want without paying out of pocket.
Thanks for the tips. I did not know the google survey trick.
One question about the track you record on your phone. I saw that you can choice between many different settings on the app. Do you have always a good quality of sound if you record 44.1, 48 khz 16 or 24 bit.
I know it is maybe a lot of question. But I you like to understand why sometimes it works and sometimes not.
I have try the free version of the audio evolution mobile. It is the mixing app of the same company than the extream USB audio recorder. It is a multitrack recorder who can use the android driver or the house made driver for recording. They and other website review said that it should be the solution.
For now I have the same problem.
I do not like the idea to help Google and theirs algorithm. So maybe I will buy the audio app and see if it is working on my phone.
It could be terrific to have the ability to master out with a phone and the usbc (other than iPhone).
However its done I am down to support devs with $. The app works. 't like You can try it and get a refund if you don’t like it. The time window is short so do it when you have op-z in hand and are ready to test.
