Is it possible to use the NI Maschine Mikro as Midi device with the USB port on the OPLab?
I am aware that the big Maschine comes with dedicated Midi Out ports which should work. The Mikro doesn’t. However when you connect it to a PC it is possible to turn it into Midi Control mode using SHIFT + MIDI. When connection the Maschine Mikro to an OPLab via USB it does light up but I cannot switch modes. :-/
I wonder did anyone get this to work?
