Hey guys. So, I just got this OP-1 (used) and I want to make sure that this isn’t a hardware or possibly setting issue I’m having here because it just doesn’t seem like a desired behavior…
Should I be able to switch between Tracks 1-4 while the tape is playing something I’ve recorded and not have the volume cut-out momentarily as I’m hitting a track number?
it’s a tricky routine to master. identify the track absolutely essential to keep going so sound doesn’t cut off, and press that first and hold while you switch to your destination track. that’s how the lore goes ;
