Hey ![]()
I think we found the issue ![]()
A very helpful test user just pointed this out to me and confirmed his working setup on an iPhone 13 with Lightning.
A direct USB-C to Lightning cable does NOT work. You need an Apple Lightning to USB 3 Camera Adapter, or a compatible third-party equivalent that supports USB host mode and external power.
With the Apple adapter, you also need to connect external power to the Lightning charging port on the adapter.
So your iPhone SE running iOS 26 should hopefully work fine with this setup โ connect power to the adapter, then connect the OP-1 Field to the USB port.
Thanks for testing this!
