Heading out on a week-long trip and just bringing the OP-1. I’m wondering what some peoples favorite stuff to load their OP-1 up with is. Sort of bread-and-butter stuff if you will.
80s drum kits
starve it. see what happens without samples.
Exactly, leave with an empty tank and use the OP-1’s built in radio for local flavors.
If you don’t have the antenna, plug some headphones in. So take 2 pairs of headphones
where are you going?
If you don't have the antenna, plug some headphones in.
I think both input and headphone output act as antenna connectors. One pair is enough ;
I like to empty the little beast and then make samples throughout the day and make a track before bedtime.
Collect your trip in sound rather than or as well as photos and you will hit gold every time.
@lefilou Great ideas, I’m going to Mexico, so I should have a lot of fun with radio samples.
If you don't have the antenna, plug some headphones in.I think both input and headphone output act as antenna connectors. One pair is enough ;
Hmm not sure, I mostly use the OP-1 with headphones and could def tell the difference between having additional headphones plugged in the input, or not.
@lefilou Great ideas, I'm going to Mexico, so I should have a lot of fun with radio samples.
haha there you go!
A spare 3.5mm aux cable should work just as well as a second set of headphones, right?
that’s what I use. that said, headphones are coiled, so somewhere in there a chance for better reception… if that matters to you
Fwiw I picked you’ll my aerial for £1 on eBay! Works fine.
I bought a TE antenna. A 3.5mm aux cable works better imo.
This is a great option! Works excellent as an antenna plus you’ll have the ability to sample audio directly from your phone, if desired.
