It’s a loop from Logic/Garageband so it’s already sliced perfectly ready to repeat.
Here’s what I’ve tried
• recording it from GarageBand into the op-1f via usb-c audio
- the problem: I can’t get the timing right; when I go to slice the end of it, it always ends up out slightly.
• adding it as a wav file called “track_1” in a tape folder inside the op-1 using mtp. Also tried making the file exactly six minutes long.
- the problem: the op-1 doesn’t seem to see the file.
• adding it via mtp to the drum sampler
- problem: it wants to slice it and even when I make it as large as the file itself, it still won’t loop it properly.
• adding it via the synth sampler
- the problem: the synth sampler cuts it off half way through and repeats from there. No idea why. Probably a restriction on the length .
Even when I;ve got it in there’s also the added problem of trying to match the tempo because I want to be able to shift right arrow through the bars.
Am I overthinking this?
The reason I was trying to do it was because I previously was trying to get a 4/3 grid and that wasn’t working at all. Seems like unless you’re using 4/4 and recording directly onto the op1 from the op1 you may as well ignore the grid?
Which is annoying!
Can someone help?
