Hello
I purchased OP-1 a few days ago.
However, every time I turn on the power, I get a loud noise from the built-in speaker.
And every time I make a USB connection to my computer, I get a loud noise from the built-in speaker.
However, there is no noise when playing a song.
And, when the power is turned on with the USB connected, the speaker does not generate noise.
I am very dizzy because of this problem.
I am afraid my beloved OP-1 might have broken down.
Give me the solution.
P.s1: When I searched Google, [Shift + COM] >> 4 (opt mode) can be used to eliminate ground loop noise. But that did not work for my OP-1.
P.s2: There is one more question. USB charging continues even if disables are applied in opt mode. Why is this?
