Press a different key and then turn hold and viola it plays/holds that key.
it doesn’t do that for me. it always just plays the drum pattern (at the same pitch the drums were sampled) for me in version 220. it doesn’t transpose the samples up and down as if you were changing key. is that what is supposed to happen? pressing the keys while “hold” is on just plays notes for me.
Sounds like something is wrong with the firmware, as it should transpose when you play different keys. I’d suggest you either treat 220 like a beta version (not sure why it’s even on your unit, maybe an accident?) and help become a bug tester, or roll back to the official 218 firmware.
Overall, Peter, it might be worth putting all your discrepancies/problems with the OP1 into an email and speak to TE. Or at the very least making a single topic with the things you think are wrong, rather than commenting on multiple threads at once.
I think majority of the users here on the forum are quite aware of the limitations, quirks, and overall weirdness of the OP1. Most of us (me included) have become Operators simply because there’s nothing out there like this device, and the quirks make up a large part of this - it feels less of a machine and more of a quirky robot. No, it’s not perfect. That’s what makes it special.
Just pointing out all the things that you think is wrong with it is simply not helping anyone. And one mans trash is anothers blahblah: to me, “hold” makes perfect sense. To me, the sequencers work as they should as the sound is right (again, sounds like a bug in 220 is causing you issues with the playhead). Arguing about semantics doesn’t help either - regardless of if you think it will improve the product or not.
If you really want to improve the product or help with development, speak to TE and see if you can be a beta tester/fixer. If you want to engage with a community built around working within the strangeness off the OP1, coming up with creative solutions to limitations, and just make some MUSIC, then I’d suggest you stop harping on about things you see as detrimental issues. This isn’t meant as a personal attack as I get a lot of what you’re saying, especially from a technician/designer point of view, but honestly I don’t think this forum is the place for bickering back and forth over this kind of thing. I’ve never seen a thread go to the dogs on this forum before this particular thread came up. No one wants this forum to become GS…
@admin can I suggest this thread be closed
