Probably because it takes 6> seconds to chromatically map a sample using Synth Sampler (as it does it automatically). Multi-sampling using the drum sampler takes far longer. Also, with the 12 seconds for the drum sampler, if you spread that across the entire 25 keys you’d get less than half a second per key, which is not enough for anything other than strikes or un-sustained plucks
It’s not better. It’s just different and serves different purposes. The Synth Sampler recognizes embedded loop points when importing samples. Very good for sustained sounds.
Yeah you can create more interesting sustained ambient keys w/ the synth sampler.
Thanks to both of you for sharing your thoughts.
Sure, multisampled sounds are far more effective when sampling acoustic and electro-acoustic sources and if it fits in the space allotted, there is no reason not to use the Drum Sampler.
fwiw, u can use some old school techniques to fit more than 12 seconds into one patch.
There’s anti aliasing filters on the synth so it sounds smooth when playing speeded up samples unnaturally slow.
The drum sampler gives freq shift FX when using @docshermsticks technique at the extreme.
In theory synth is better quality ,but that drum sample freq FX can sound cool.try resamples at extreme speed changes via tape.
The looping is superior on synth.plus synth envelope.
I love and use both. Unnatural doesn’t necessarily = bad.
Being able to set the loop return point on the synth engine is crucial to certain tasks. Also, no pitch bend on the drum sampler.
i’m the opposite. the drum sampler is…meh. it sounds flat and is pretty featureless compared to my other samplers.
but i like the synth sampler – my analogue synths sound really good when sampled into the synth sampler.
I love it. Drums sound crunchy AF in the drum sampler.
Yes -no pitch bend is a shame.
No fine tune and no sketch pitch.
Also no mono,uni,legato.
I love it. Drums sound crunchy AF in the drum sampler.I sampled some drums in tonight from the Digitakt, had overdrive on the Digtakt at about 70%.
Love the drum sampler but jeez what is up with that envelope? Anyone learned to love it?
fwiw, u can use some old school techniques to fit more than 12 seconds into one patch.speed up your samples before sampling or importing via drum utilitythen pitch them back down in the drum sampler to original pitch.classic mid 1980s move right there.
I rarely read a post by this guy without gleaning some amazing new insight. Kudos!
I wouldn’t say I love it so much as it’s still functional, and you get some fun results.
Love the drum sampler but jeez what is up with that envelope? Anyone learned to love it?I like it, definitely designed for drum envelopes though.
I love both, very diff applications. In regards to 12 seconds on 25 keys (drum samp) I use all that extra real estate for backwards trigs and pitch shifted trigs
Sampled my aunty’s piano. Wildly hitting all 24 keys in 12 seconds is fun. I think skipping keys might get better results. Ie. Hit just white keys and pitch the rest. Or even just hit black keys. Or one octave of real samples, then pitch second octave. Allows for longer samples. Or you could have an octave of hard and an octave of soft strikes in one patch. Fun to experiment with.
