You need the CCK dongle
@alozola I can’t seem to find any specs on the Roland GO:Mixer as far as conversion rates. For the purposes I’m using it, it sounds great.
@alozola I can't seem to find any specs on the Roland GO:Mixer as far as conversion rates. For the purposes I'm using it, it sounds great.
Anyways, even a 16bits/44Khz conversion rate is ok. I mean, into the mix and under the distortion stages I usualy use in my tracks, I don’t think I’ll be able to do any difference.
You need the CCK dongleGot that. It says no longer supported. Thanks for getting back to me :)
@HisMostDarxxxellent
Do you mean your Duo Capture EX don’t work with your iOS device?
Sounds strange to me, as I use it every day without any problems.
Are you set the switch on the back of the Roland on the “tab” position?
