https://www.muffwiggler.com/forum/viewtopic.php?t=137252&highlight=
Are there others yet? If not, let’s harass Aman ( link )!!
That is all.
That is all.
whilst that is actually pretty damn cool, it seems a bit pointless without adding cv inputs to actually allow you to interact with the PO beyond running signal through it…
I think someone did something just because they can, and didn’t stop to think if they should
I just want more things racked to streamline things - I know it would be a stupid way of killing hp, but I’ve got to kill a cell 90 case and I feel like I’d use my PO-12 more often that way. Otherwise, it’s been neglected :/.
Here’s mine. Enjoying having it in the rack. Will hook up the 4 separate sockets today so I can sync.
Awesome!
@robman’s panel takes up less space and I like the layout of the jacks better.
And I just realised that’s an iDevice next to it. Amazing
Oh my god, these are all really cool!
Thanks for the kind words. Although mine is narrower, I had to shave about 1.5mm off the height to get it to fit within my rails. I tried to take it off the jacks, but couldn’t, so I took it off the bottom of the PO-14 (you can see that in the large image). I also just soldered up the jacks and found although they work fine, the PO-14 must have a plug in each jack for it to be recognised (presumably it uses the switch of the jacks). I could probably fix that but I don’t want to permanently change the PO-14 (the mod uses connectors so is removable). I just found some old cheap earbuds with right-angled 3.5mm plugs in a box somewhere, so I chopped those off and it works just fine with them plugged in. Successfully tested clocked from, and clocking, my Volca Bass from the new jacks. Very pleased!
