Nothing at all happens. Sigh. Didn’t even hear Windows make that bloopy sound it does when a USB device is connected. It just does nothing.
Wow.
If I plug it in then turn it on, it makes the sound, but then nothing happened at first when I went into disk mode other than making the disconnect sound. So I did it again, and waited maybe 15-20 seconds, then enabled disk mode, and it did the driver install thing, and I can access it, now. However, leaving disk mode and going back to OP-1, I cannot enter disk mode again. it actually crashed my OP-1 and it wouldn’t turn off, which is new o.O it did turn off eventually, but the text all over the screen was new to me… it even said a file was missing, something about drum something iirc.
So.
1)Plug in powered-off OP-1
2)Turn on OP-1
3)Enter Disk Mode
4)Wait 15 seconds for some whack ass reason
5)OP-1 disk appears in Explorer
6)…
7)Profit!
And apparently I also have an intermittent open in my USB cable. I keep it folded how it came, it tucks into some loops on the Unit Portables case, but over the years I guess it wore out at a bend near the small connector >.> (shaking it there makes it disconnect/reconnect)
Ok news
No luck with win7 on other comp
Contacted support. Gotba very quick answer. They told me to run the battery to nill. This will reset the system (not my recordings). I’ll come back later.
Thank you all for the feedback so far. @KrisM I waited more than a minute and tryed different styles of power-ups…
