Wont switch on unless usb cable is plugged in
#1
regardless of battery life. This is happening now, usb just has to be plugged into the unit, not actual power. Anyone else experience this?
#2
Try a backup then factory reset?
#3
@Mdura
#4
@Warpwhistle any luck with @darenager 's tip?
#5
Wont power on at all now
#6
i had the same issue last year but the USB transfer wasn’t working also, apparently the main ‘dsp pcb’ was in cause
#7
How did you resolve?
#8
It happened to me twice since 2015, i did send it back to TE for a repair under warranty, last time (may 2017) it took 6 months. I hope i’ve just been out of luck, but since i’m careful about what i connect the OP-1 to.
