XY Drumkit service
There is a new way to create drum kits, it is drag and drop!
https://preset.operator-xy.com
Drop your folder into the space and it will make a preset folder in a zip which you download and unzip.
Then drop into your OP-XY presets
->We are not directly affiliated with TE, this is not a TE product<-
Thank you! I can’t wait to get a chance to check this out.
Whoa. Awesome! I’ll give this a try.
very cool - nice work on this!!
awesome!! Thank you!
All works as expected! It’s just that the presets default to octave -1, so you have to change to octave 0 every time. Why is that? Cheers!
yeah json issue… Until It is fixed you can change it manually in the JSON too.
At the top, just before the list of samples change octave from -1 to 0. just change that number and you should be fine.
[23095,16384,15889,16000,0,0,0,0],“type”:“tremolo”},“octave”:-1,“platform”:“OP-XY”,“regions”:
[{“fade.in”:0,"fad
[23095,16384,15889,16000,0,0,0,0],“type”:“tremolo”},“octave”:0,“platform”:“OP-XY”,“regions”:
[{“fade.in”:0,"fad
Thanks a lot! I eventually figured it out on my own… but I also ended up not using the presets anymore because they crashed the device when browsing. I’m shure it’s a TE issue. But until they fix it, I am sticking to the factory ones.
Cheers again! Your tool is awesome and I have it in my bookmarks for when THE update comes along.
It has been updated.
What are the errors? I use it so often and I have not had sample issues in a very ling time. Would you share your screen crash and if you are willing the drum kit that crashes?
Thank you! I will try again now that an update has come along. If there are crashes I will share the screens and/or the kits that caused them. Cheers!
In the beginning there were samples which had bad headers which caused crashes but it was not related to the tool. I would see if those samples would crash your XY in any case. If you resave the sample and try again helped my issues until TE had addressed it.
This is really a great utility!
Thank you for making and sharing it!
NOTE:
It works fine with .wav files, but I noticed that the preset created with .aiff files did not work on the OP-XY (even though in the documentation TE says that it should play either .wav or .aiff files). Not a problem to convert the files to .wav but am leaving this note here in case someone experiences similar issue.
