Plainjanefrancis, you’re first! Then winerz, Vehka, me and finally LyingDalai.
The rules summed up:
T1 panned left, T2 panned right, T3&4 centered. No global effects. Master: 60 (drive), 30 (release). 30 SECONDS! The last 3 seconds can be used for transition by the next guy. No limits regarding style or sound, only try to make the track sound coherent as much as possible. Lifting parts from previous contributions and reusing them is allowed, however, the previous parts have to stay as they are! Plainjanefrancis will provide the BPM with his first contribution (should be somewhere between 80 and 160, though)
Here is a DB-Folder we can use for the files:
Just copy the 4 track files into the folder and a bounced version for people to listen without having to import the files into their OP1. I will always backup onto my HDD whenever a new contribution has arrived!
Well, I guess you have to check this thread every now and then. ;) But I'll send you a PM when it's your turn! I've sent one to Plainjanefrancis already.
Generally I’d say the faster the better. But you shouldn’t need more than one week.
I’ve contacted Plainjanefrancis already (3 days ago) but he won’t answer. Winerz! Would you mind starting then? If no, here’s the new and complete order:
