Required intro/outro samples
Use this fade-out drone sample [intro.aif] as the BEGINNING of your track and this fade-in drone sample [outro.aif] as the END of your track
Be sure to add this at the very end of the process if you plan to use tape speed adjustments to your track in order to preserve pitch.
The idea behind is to unite all the tracks in the end.
So it's important to keep at least a few seconds untouched for the beginning of the intro sample and the end of the outro one !
These samples are offered as drumkits, so put the e.g. in /drum/battle #43/ and load them in a drum slot.
First note is the whole sample. Rest of the notes are ideas of what you can get out of such samples :D
Required sample from past battle
The second required sample must come from an entry from the previous OP-1 battle that corresponds with the number you roll above.
Example: if your number is 34, you must use a sample from an entry in Battle #34
For battles 1-30 you may use this thread for reference.
If the entries can not be found for a battle (example: battle 15), you must use the immediately following battle.
No other sample allowed
Along with the samples mentioned in rules above, use only internal sounds synthesized in OP-1 (metronome included).
No drum or synth sampler filled with external samples : drum + synth samplers only OK for resampling.
You may use a computer for the only purpose of building your drumkits ("OP-1 drumkit utility" may be used for this)
- All mixing must be done on OP-1
Deadline
December 4th, 23:59
33 - all right
37 - I’m a first timer. !!!
I’m a bit confused about the rules…
I rolled 28. I’m in, and I swear to keep the deadline this time (…or die trying…)
- ready to go.
I rolled 36
- I’m in.
- first time doing a battle so we’ll see how it goes
@interpolate @motone indeed the idea behind is to unite the tracks in the end
So it’s important to keep at least a few seconds untouched for intro/outro samples.
Now you’re free to reuse it
And @motone is true : only internal engines are allowed, no external samples but the ones extracted from rule #2 (and #1)
@motone please don’t die
At least no too soon.
Also one more thing. Can someone explain the process of getting those drones onto the OP-1 at the beginning and end of my track? I’m sure i could figure it out with the sampler but I feel like there’s a much easier way. Got this thing a month ago so i don’t know much about it yet.
@zach_aum, here are the options that come to mind:
Battle sounds cool
I got 23.
I’m glad you liked the generator idea
@Konst @himrod @LyingDalai. Nice battle guys !
I hope I’m gonna have time to participate to this one, as I’m actually buying a house and just received Ableton Push…
This should be the opportunity to erase my OP-1 tape and get something new on it,
I rolled 39
Mecha Tassadar - ONLINE!
Interesting challenge. After just getting my hands on a OP-1 I have really been looking forward to participating in battles, as it does seem like an cool way to learn its features and pump up the creativity/productivity.
Lucky guy, @Rokoko, you got the one that started it all off
Got 37, if I ever find the time to submit my own track ^^
@yoof, maybe this thread should be made sticky ?
7! Lucky for some.
Hopefully I’ll come up with something.
Finally registering for a battle is an excellent first step at least!
