Ahaha yeah, that’s an idea @yoof ^^
@LyingDalai so when can we expect the new samples?
Pressure pressure !
I can’t open the aif files you provided, I’m on my business computer, but even ableton says it’s an invalid format. Am I the only one ?
I´m in. Got 8.
I can't open the aif files you provided, I'm on my business computer, but even ableton says it's an invalid format. Am I the only one ?
You can’t right-click and save, that’ll give you files that are ~500Kb and doesn’t work. You have to log in to dropbox and download them I think, at least that’s the way I got it to work.
No you don’t have to log in to dropbox, you can just dismiss the popin.
'No drum or synth sampler filled with external samples'
@borden You’re allowed to arrange the sounds you’ve created with the OP-1’s internal sound engines (and the samples from rule #2) into a drumkit, using your computer and the drumkit utility. No other samples from external sources, and no sample presets from the OP-1. No external processing (except cutting the pieces).
But I'll recreate these samples so that they fit the synth sampler anywayGreat, that would make it easier.
Thanks for the clarification! Great rules
I got 5, sounds cool!
So here are the samples (as drumkits)
Should be good
32! Looking forward to try this
27; Looking forward!
@borden You're allowed to arrange the sounds you've created with the OP-1's internal sound engines (and the samples from rule #2) into a drumkit, using your computer and the drumkit utility. No other samples from external sources, and no sample presets from the OP-1. No external processing (except cutting the pieces).
Hey, also clarifying here, sorry about the constant questions haha. What does “no sample presets from the OP-1” mean? Like no drum kits from the OP-1? My plan was to sample the part from the battle number i received and then just build a song using the synth and drum patches on the OP-1, which was going to include some of the loaded drum kits. Is that not allowed?
@zach_aum you’re right. Stock drumkits or samples from OP-1 not allowed. Synthesize your own drum sounds with the OP-1’s synth engines (including resampling), and/or refer to rule #2 (a sample from the former battle entry).
@zach_aum you're right. Stock drumkits or samples from OP-1 not allowed. Synthesize your own drum sounds with the OP-1's synth engines (including resampling), and/or refer to rule #2 (a sample from the former battle entry).
Okay thanks for the help! Will be a challenge but it’ll be fun.
Exactly : the challenge is really to learn to synthesize and build drumkits from scratch!
A challenge indeed, but very interesting experience IMO
Once you’ve built your drumkits, you can of course load them in the quick presets spots 1 to 8… But no stock presets !
