Hey all
Sorry for the long post, but a while ago I made an overview of the different battles up till now. Didnt finish it yet. Might do so later on.
I’m continuing the work by @kln from this post:
up to Battle 23
For more info on Battle search for corresponding Battle (24 is earliest on this forum)
Basic Battle standards, as laid out by KLN: battle standards
Extra battle idea’s by KLN and others: battle/song ideas - #17 by Plague
Sample:
April in Paris – Duke Ellington
Cuckoo’s vocals (Flightofthecuckoo – Popcorngirl-lead-vocal 2)
Sampling of body noise
James Brown break and BT Express break
use or combine Serge Gainsbourg & Jean-Claude Brialy "Un Poison Violent, C’est Ça L’Amour” & Herb Alpert “Besame Mucho”
any material you find from the singer Fairuz on youtube
sample or record your analog sounds of your synth to tape or the synth/ drum sampler and then sequence them with any OPsequencer.
one note of you’re favorite sound.
sample a Pocket Operator into the OP-1
the NASA soundcloud Stream NASA | Listen to podcast episodes online for free on SoundCloud
sample any De La Soul material
sample/record your local environment
Sample any audio from the movie “The Hitchhiker’s Guide to the Galaxy”
Required sample from past battle based on random number
Cover:
create a cover song
use quotes from a Hitchcock film
the track must include the five note theme from Close Encounters
Remix a song that uses traditional elements from where you are from or a place you identify yourself with
covering or remixing an Aphex Twin track of your choice
Synth restriction: Dr Wave (2), Dbox (5), Strings (1), Phase (1), Digital (3), FM synth (1), DNA synth (1), cluster (1), Dsynth (1), Slump (1)
Kit restriction:
MXD drum kit, Hortlax kit, Rhodes Chroma, MachineDrum and/or “MDTAPE” and/or "Traps” internal kit, FlatTop preset drum kit, Use up to 3 of the new drumpresets (in 2016)
Sequencer restriction:
Endless sequencer (1), Tombola (2)
Fx restriction:
- use delay(a little or a lot) on all 4 tracks ( and the master fx if you dare) no other fx are allowed
- Use telephone or Cwo or both in every track (optionally in Master but other fx are allowed here.)
Special rules:
Exploit unintentional noise, bugs and glitches
All sounds had to be derived from the internal metronome
Length restriction of 30 seconds
Feature a tempo change somewhere in the tune
make use of “counterpoint” with only one synth
sample and use a bit of local radio mentioning something about where you live
Be inspired by a painting. Include the painting in your title.
At least 1/2 of the tune must be in an ‘odd meter’
- Record with the OP-1 a battery powered sound making device. Any devise is permitted to be used as long as it is unable to connect to the internet.
- you should make ONE field recording, for example nature sounds (wind, ocean, walking on grass, etc), city sounds (traffic, bikes, people walking, etc)
- Only one track and one bounce may be processed with external hardware FX
Create a musical piece, where the left and right stereo channel are completely different, and even would work as separate pieces.
Play at least one acoustic instrument
collaborate by sharing your set of synth and drum patches; combine yours with someone elses
Use 1 internal synth defined by a random number
Add 84 to your random number, You’ve got the BPM for your track !
Battle 1
allowed to sample “April in Paris” by Duke Ellington
must use Dr. Wave on one track
https://soundcloud.com/ohpeewon-battles/sets/battle-1 15
Battle 2
- use ?sample? from VST and Co. - Step no, step yes.
https://soundcloud.com/ohpeewon-battles/sets/battle-2 1
Battle 3
only use Dr Wave and Dbox synthesis
use ?sample? provided for the battle
https://soundcloud.com/ohpeewon-battles/sets/battle-3 3
Battle 4
- Only use strings and dbox synths.
https://soundcloud.com/ohpeewon-battles/sets/battle-4 4
Battle 5
- only the synth engines Phase and Digital and the onboard mic as audio sources.
https://soundcloud.com/ohpeewon-battles/sets/battle-5 2
Battle 6
- use only the FM synth engine and the DBOX drum synthesizer.
Stream - ohpeewon battles - | Listen to Battle 6 playlist online for free on SoundCloud
Battle 7
allow use of an external instrument for the beats.
can sample Radio and internal engines allowed
Stream - ohpeewon battles - | Listen to Battle 7 playlist online for free on SoundCloud
Battle 8 or 9
- exploit unintentional noise, bugs and glitches in the software in the OP-1.
Stream - ohpeewon battles - | Listen to Battle 8 playlist online for free on SoundCloud
Battle 9 or 8
use the ?break beats provided?
only use the DNA synth engine (with any effects and resampling)
Stream - ohpeewon battles - | Listen to Battle 9 playlist online for free on SoundCloud
Battle 10
- use only the cluster synth engine.
https://soundcloud.com/ohpeewon-battles/sets/battle-10 1
Battle 11
- use only the MXD drum kit & the Digital Synth engine
Battle 12
use Cuckoo’s vocals (Flightofthecuckoo – Popcorngirl-lead-vocal 2)
use the Pulse Synth engine & Live drum kit
Battle 13
use samples from a Rhodes Chroma
use the Hortlax kit
Battle 14
all sounds had to be derived from the internal metronome
a solo was required
Stream - ohpeewon battles - | Listen to Battle 14 playlist online for free on SoundCloud
Battle 15
- allowed only the use of DBox
Battle 16
- something to do with only being 30 seconds long & only OP-1
Stream - ohpeewon battles - | Listen to Battle 16 playlist online for free on SoundCloud
Battle 17
Track 1 can use any body noise using the Drum Sampler - no sequencer. lifting and dropping permitted
Track 2 has the same rules as Track 1, but using the Synth Sampler
Track 3 must use a vocal, but can be either Sampler. Only Tombola sequencer is permitted, and can lift and drop.
Track 4 needs to be series of live takes, either external or internal. no sampling, sequencing or lifting/dropping.
Stream - ohpeewon battles - | Listen to Battle 17 playlist online for free on SoundCloud
Battle 18
capture all audio using the endless sequencer
feature a tempo change somewhere in the tune
Stream - ohpeewon battles - | Listen to Battle 18 playlist online for free on SoundCloud
Battle 19
- notes entered to tape with tombola hexagon sequencer
Stream - ohpeewon battles - | Listen to Battle 19 playlist online for free on SoundCloud
Battle 20
- create a cover song using OP-1
Stream - ohpeewon battles - | Listen to Battle 20 playlist online for free on SoundCloud
Battle 21
- use quotes from a Hitchcock film
- get some use of the sketch sequencer in.
- make use of the new DSynth engine.
https://soundcloud.com/ohpeewon-battles/sets/battle-21 2
Battle 22
all sounds must come from D-box, DNA, or D-synth
Stream - ohpeewon battles - | Listen to Battle 22 playlist online for free on SoundCloud
Battle 23
- pick one setting of a single synth engine and make a track out of that. no resampling, no changes to the synth setting, no drums.
2 also make use of “counterpoint”
Battle 24
- make use of two clips of provided breakbeats for the drums - James Brown break and BT Express break
- use just one synth engine
- sample and use a bit of local radio mentioning something about where you live
https://soundcloud.com/ohpeewon-battles/sets/battle-24 1
Battle 25
- use or combine Serge Gainsbourg & Jean-Claude Brialy "Un Poison Violent, C’est Ça L’Amour” & Herb Alpert “Besame Mucho”
- use only the drums sampled from the songs.
- all other engines allowed to support combining the two.
- radio is allowed to combine another song with it’s samples to it.
- feel free to be creative with the samples and engines, but don’t forget to have parts with significant sample-use.
Battle 26
- entries must feature DSynth
- entries must contain sounds from FlatTop preset drum kit
- entries may feature ONE synth engine to compliment DSynth (sampler not counted)
- the built-in microphone may be used to capture sounds to be added to the track (think voice, guitar, twigs, coins, tupperware, ambience…). (external mic for folks with broken ones)
- YouTube may be recorded (for anything, but nature is encouraged)
Stream - ohpeewon battles - | Listen to Battle 26 playlist online for free on SoundCloud
Battle 27
- allowed to sample any material you find from the singer Fairuz on youtube. no other external sampling allowed.
- prepared a drumkit for you to use, featuring a bunch of sounds from a MachineDrum, “MDTAPE” and/or "Traps” internal kit
- only 3 types of effects throughout your track. and to mention which ones you’ve chosen when you submit your track.
Stream - ohpeewon battles - | Listen to Battle 27 playlist online for free on SoundCloud
Battle 28
- sample or record your analog sounds of your synth to tape or the synth/ drum sampler and then sequence them with any OPsequencer.
- add any drums from the factory presets or use your analog drumsounds.
- add only ONE synth engine of the OP-1
- maybe use radio to sample voices to make it more interesting
https://soundcloud.com/ohpeewon-battles/sets/battle-28 2
Battle 29
- sample one note of you’re favorite sound.
- you can use all the internal effects, copy-paste-cut and tape tricks to shape this one note in new sounds you can use. Creativity is your friend.
- so only this one note and mutations are allowed… no internal synths and kits (sorry guys!)
- use a painting as an inspiration for your ambience/composition. (painting also includes graffiti, comix and illustration)
- the song title has to be inspired on the painting of choice.
https://soundcloud.com/ohpeewon-battles/sets/battle-29 1
Battle 30
- all internal synths and drum kits are allowed
- record and mix everything on the op-1 ( as usual )
- maybe use differnt delay speeds on your tracks to create cool rythms/ textures https://soundcloud.com/ohpeewon-battles/sets/battle-30 4
Battle 31
1.Use telephone or Cwo or both in every track (optionally in Master but other fx are allowed here.)
https://soundcloud.com/ohpeewon-battles/sets/battle-31 1
Battle 32
- sample a Pocket Operator into the OP-1
Stream - ohpeewon battles - | Listen to Battle 32 playlist online for free on SoundCloud
Battle 33
- Sample from the NASA soundcloud Stream NASA | Listen to podcast episodes online for free on SoundCloud
- At least 1/2 of the tune must be in an ‘odd meter’
Stream - ohpeewon battles - | Listen to Battle 33 playlist online for free on SoundCloud
Battle 34
(tracks in the voting page; no playlist)
Battle 35
- Remix a song that uses traditional elements from where you are from or a place you identify yourself with
- you should make ONE field recording, for example nature sounds (wind, ocean, walking on grass, etc), city sounds (traffic, bikes, people walking, etc), and use it in your remix. no limits on the length of this recording.
Battle 36
- Sample any De La Soul material
Battle 37
- covering or remixing an Aphex Twin track of your choice
Battle 38
- Create a musical piece, where the left and right stereo channel are completely different, and even would work as separate pieces.
- Hard left and right panning, no center tracks.
- No identical sounds at the same time on both channels (but you may play the same notes with different sounds or use a delay.)
https://soundcloud.com/ohpeewon-battles/sets/battle-38
Battle 39
- Record one sound when you’re waking up, and use it in the synth sampler.
- Sample or record (tape, synth / drum sampler) a voice/speech of people who speaks the language of the country where you live now (this could be recorded from a public transport, conversation, radio, ads, colleague, boss…).
- Play at least one acoustic instrument of your choice. If you don’t have any acoustic instruments, you can use glasses, or everything natural with which you can make noises.
- Only Digital Synth synth engine is allowed.
Stream - ohpeewon battles - | Listen to Battle 39 playlist online for free on SoundCloud
Battle 40
- Collaborate by choosing a single Operators set of samples and patches to leverage, post your own set of samples or presets
Battle 41
- Use slump (precursor of voltage) and only one other synth engine of your choice.
- Use up to 3 of the new drumpresets
- Record one sound of your pet and play with it on the sampler engine, synth or drum
Battle 42
- Sample any audio from the movie “The Hitchhiker’s Guide to the Galaxy”
- Use 1 internal synth defined by a random number
- Use this synth with the TOMBOLA Sequencer (at least 1 track)
- Add 84 to your random number, You’ve got the BPM for your track !
Stream - ohpeewon battles - | Listen to Battle 42 playlist online for free on SoundCloud
Battle 43
- Required intro/outro samples so all tracks can be united
- Required sample from past battle based on random number
Stream - ohpeewon battles - | Listen to Battle 43 playlist online for free on SoundCloud
