Hey guys, I have a problem.
Everything on the OP-1, except the master mix and master effects, is mono. So when you lift something into the sampler (or onto another tape track or wherever), it will be converted to mono.
To sample from album, you just set the sampler source to ear I believe. You go to album and press play (T2 I think), then record to the tape or directly in the drums or sampler synth.
But of course, when you sample from the Album, you will get a mono version because the Sample engine is mono. Maybe try and get your drums to sit together better using EQ?
Right, OP-1 works in mono, like @yrn001 said. You have two choices :
What I’ve done is multi a drum break. I made three copies and tweaked each one by lifting them into sampler and EQing with nitro (one for highs, one for lows, one for slam compression). I sampled each back to tape on separate tracks and mixed with the mixer.
Okay two tracks it is! Thank you!
@cloudburst you’re right. Mixer sends to Output too, Album is an option.
@lyingdalia Ah okay - of course.
With album is there anyway to precisely record back in or is it all timing?
Yep it is confirmed. Album saves the stereo quality. Even if it isn’t stereo the sound is the same!
@cloudburst Album is also a way to get a single stereo track, clean and done, in which you can also immortalize all kinds of interventions (drums/synth/sampling/master effects) while playing/tweaking the tape… Of course you can do this with a DAW using the stereo output of the OP-1.
if you use the sequencers to add drum parts bit by bit on two tracks, you can emulate a real mic’d drum kit by utilizing the master panning (hard L on T1, and hard R on T2, for example)…and then use the orange knob when recording to control the volume.
Awesome thanks @kln ,I love that little insight to your process.I’m aware of the old Panning Tips thread,but this makes it clearer how you get your nice drum mixes.I had guessed at you paying attention to Orange in Tape mode.I may have a go at this.Good stuff
(Now i must sort out that SoundCloud account ,so to enter something,anything into a battle…)
@kln this is awesome.
@Spheric_El - i do pay close attention to the Orange encoder in Tape mode. even if you aren’t using the spatial plotting technique i tried to describe, even fluctuating up and down in small increments as you play a sequence or key in sounds can add some dynamic feeling to the recording. in a DAW with MIDI you can quite easily change velocity, but it is much more manual on the OP-1. the Orange encoder is the ticket. once you get the hang of it, and find which sounds it makes sense to flux in your mix and how to vary them over time, it can produce some subtle change through your recording and enhance the overall composition. you can also enhance the “rise” or “fall” of synth sound by playing with Orange while recording.
