Custom Firmware on the OP-1
Dear people of the OP lands,
it only took 10 years and AI to derail this thread :wink:
So let’s quickly summarise what is happening right now and where to go from here:
In 2016, I took apart the update file from TE and found we can manipulate small parts of the firmware by editing the files which are easily readable (the SVG files for changing graphics, and the SQLite database files for parameters and “unlocking” some stuff which was hidden in the firmware).
I then explained that to truly modify the firmware, there would be several steps involved:
That process never really happened because it is a stupid amount of work (for humans…). Some of us had the firmware disassembled in IDA pro but only partly and the Indiana Jones part of finding all the relevant entrypoints and workings of that disassembly was never really taken on because it’s tedious and “ain’t nobody got time for that”.
This is where the AI came crashing in. Basically it did all those steps mentioned back then, probably using a popular SKILL which explains to the AI how to use those reverse engineering tools (Ghidra, Hopper, IDA pro, …) check it out here: https://rea.tools/
So in essence, the AI mapped out how the binary works and where in memory all the functions are and what they do. Then you can do step 4 from above, insert/edit/delete parts and correctly inject them and use the existing functions as entry points.
basically that.
That is what all the firmwares out there are now doing, but each of them is using different approaches because AI is not deterministic and everyones prompts also differ.
Of course humans always want EVERYTHING, so the desire for a combined firmware including all the mods is understandable.
The caveats to this are:
  1. The “entrypoints” are basically hardcoded addresses in the memory layout of the OP-1 original firmware. That is why all the mods rely on #246 and exactly that version. If TE was to ever release a #247 (which I doubt at this point), the mods might fail to work on that because a new version might have different addresses for the functions and then you get random behavior and crashes.
  2. To make the firmware “easily extendable” you need a flexible “plugin system”, so that new fx and synths can be developed, fit in with the rest of the system, not interfere with each other and so on. The new custom firmwares all seem to try to solve this, but not the exact same way. That is why you have these discussions on here now.
Now in the age of AI, development happened pretty friggin fast and so there is not one but LOTS of custom firmwares, which also take parts from each other in order to get to the EVERYTHING part (or at least personal preference of it).
My best try at an overview:
As for the ongoing discussions, updates, development and future of all these, there are a multitude of places as well. Some in this forum:
and some outside of this forum:
If you want to get active yourself, I would recommend using a combination of
Now to close this: A lot has happened in the past few weeks, so it’s wild, exciting, annoying, exhausting and overwhelming to watch and try to keep up.
So chill, enjoy the new life for the OG-1 and be kind to each other along the way!
Just for story time: The original “Disclaimer” I put into the very first post in this thread has made quite the difference to how things turned out in those 2 first years…
Be respectful to each other as well as to TE and let’s have more fun and get all the new stuff more stable instead of competing.
kind regards,
TabascoEye
I just released op1r 47 and want to give a huge shout out to @Hundekraft for taking the time to optimize the engines. Some of them got to see a nice cut in CPU use, something which will result in less pops & crackles. :+1:
You really put it all in perspective, dude! Thanks​:smiling_face::heart:
Hey @_bt, did you managed any progress on the OP-Z front since? If not could you reach out with what you have so far? I’d love to look into it.
So, if somebody wants to make their own plugin - say a new synth, a LFO that can control sequencer parameters or some new tape effects for example - can this be done with little programming knowledge now? If so, I’m interested to give it a go. I’m alright with computers and can generally troubleshoot my way through things. Any other tips or suggestions? Is everyone using Claude? I’ve never used this before.
It does sound like making a synth or effect could be achievable but making tape-based effects or effects applied to the tape and/or an LFO to control the in-built OP-1 sequencer could be more tricky. But if anyone else wants to give those ideas a go, go for it. For now, I might try and make myself a My Bloody Valentine inspired synth.
Sweet, thanks for the help and encouragement. I’ll give it a go. Maybe start with a simple synth to start with. I’d like some improved tape effects as i don’t tend to use the default ones (reverse, stutter etc) but probably beyond my capabilities to change those. Other idea i had was a Beatles inspired multi-fx maybe with saturation > flanger > doubling > pitch or reverse delay.
After a few days of head-scratching, I finally got SilverTape going on OP-1 Field. Obviously personal project only, unless TE would open up official mod support for Field.
I’m running through final testing of SilverTape beta 2 for OG-1 before publication. Stereo, waveforms, dual fx, channel strip etc etc. Hopefully live today.
That’s my weekend sorted then :slight_smile:
OPUS 2 beta 3 is out
Looks fantastic​:star: is it possible to switch view from wave tracks to classic op1 tape view?
Maybe, the tape screen is a mix between tape.svg and code. Need to dig a bit. If it’s released it will be for the OG-1 though.
Would it technically be possible to create an interface 4 channel record simoultaniously to tape of op1?
that wave form view is so much better!!
Do you mean stereo recording? Right now there is no way of recording anything in stereo, correct?
Creating my own plugin is a bit above my head, maybe one day… But I’ll follow Hundekraft and hopefully more plugins use that platform as I like it the most of all.
ooooh hell yeah! good luck!
My CFW has a full stereo chain so it’s possible to record in stereo, via line in at least.
Hey, I mean more like multitracking 4 tracks onto tape simultaneously.
I’m really exited about Silver Tape’s Stereo by @maxaw aswell​:fire::fire::fire:
one can also use the tick/untick feature on Hundekraft OS builder pretty easily so the engines y’all trying to recreate in Opus are running natively on HK and you can stack & mix the engines until you think that’s enough experimentation (regarding 3.0.3) and if you always try to use all the engines at the same time and discover crackling (which is even happening on stock 246) simply wait a lil bit and you’ll be astonished by the recent implementations and performance improvements (things are happening in the background without chitchat and then open that curtain)
It’s pretty amazing :hot_dog:
